90 S4 Fuel Rail Question
I thought I read here on the forum that after a certain model year, the rubber bushings between the fuel rails and the intake were done away with...????
When I did the disassembly, there was nothing there, just the studs, but....was there supposed to be bushings in there?
PET shows them, but I'm really not convinced.
Observations would be greatly appreciated.
TIA
TIA
Archive Gatekeeper
No rubbers between the intake and fuel rails in '90.
Tom, you must have your GTS intake finished up! I saw you driving on Lamar this morning. Nice to see you up and running again!
On later cars does the fuel rail bolt directly to the intake? I had rubbers on my '87 but they are currently shot.
Basic Sponsor
You should use rubbers for safe BWAAAAAAAAAAAAAAA
Received 1,543 Likes
Intake rubbers are early '87. After early-'87 is just the studs.
IIRR fuel rails are different for rubber version. They were changed in early '87 MY but PET was never updated. It shows 931 rubbers for '95 MY GTS.
Erkka is correct. You cannot mix and match fuel rails between "rubber" intakes and "studly" intakes.
Also, the _exact_ type of bonded rubber buffer is critical. There are many different versions across the various Porsche models that differ in the thickness of the rubber and length of stud on either side. Stud length is unimportant, but, too thick rubber on a "rubber" intake will cause the injector seals to sit proud of the intake's injector ports. This will cause an intake leak, lean running, and failure to pass emissions due to high NOx.
EDIT: FYI and IIRC, the rubbers for the airbox standoffs are the correct rubber thickness but not the same stud length as the original fuel rail/intake rubbers. But, they work just fine in the rail/intake position.
Rennlist Sponsor
This will help for everyone to easily tell the difference between the early and late style fuel rails.
As you can see in the photo early version has "squared" mounting tabs/ears and the late style has "rounded" mounting tabs/ears.
Sorry for the fuzzy pic.
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
