Gain 100HP with an intake manifold change?? - Cross post from Ferrari Chat
#76
Shameless bump:
https://rennlist.com/forums/928-foru...4-intakes.html
Intake design is not that hard for a 928. Plenty of space... its just trying to get enough people together who want to pay for it. Took me years to just get enough people together to do a run of flanges.
#77
Im willing to bet, this is the answer
since greg doesnt want to partake, and carl already has the foundation, I can see a version of his design that maybe uses a EURO 2 valve U , with throttle body and the maf attachment pont that would feed right into the stock air box. there is lots of room in the "valley" of the 928 engine block, so isnt this a possibility?
more info on his intake development
http://www.928motorsports.com/instal...oldarticle.pdf
the entire idea i have here is to make it near plug and play. the stock throttle body mechanisms mount to the side of this thing, as do the vacuum lines etc.
stock MAF, and maybe a way to use the euro 2 valve U and some after market throttle body, although i think the 3.5 " euro TB should be adequate, unless the 85 us TB is better.
#78
You definitely need to read good books on volumetric efficiency, runner length and flow when it comes to the construction of an intake.
By no means am I an expert in this, but I do believe runner length and tapering may have a lot to do with how Greg was able to create the gains he did with his setup. Hell, with any setup this is imperative to have knowledge on.
again, im no expert either, but you can see what the other manufacturers desingns have brought as far as power to some small street type engines, making 330rwhp, out of 4.3 liters and near 440rwhp out of 5 liters.
we dont need to match the gains in all areas, but its a good sign that we can approach those gains . heck, even 50% of those gains would be worth it , if most of it is coming from the intake, which it is.
#80
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
How about "WE" all cobble our heads together to create a feat of engineering using the wealth of knowledge many have on the boards, even if it is the most miniscule.
Leave the bickering in the HS girl's bathroom about what tampon is better.
#81
would you just please STFU.. what are you, 7???? dont try and and be a tough guy internet bully... it doesnt work with me you pipsqueak!
read mongo below... he describes you perfectly...... "i want the one with the wings" you say??
thank you ! agreed!
thank you ! agreed!
Koenig-Specials 928 (08-16-2020)
#82
Fuse 24 Assassin
Fuse 24 Assassin
Here is a sample of a sectioned intake manifold by FAST for LS applications. I think something similar can be done with the 928..
Here is the link to the article providing the pic.
http://machinedesign.com/archive/com...ne-performance
#83
Shameless bump:
Yours are truly works of art !! Like most fabrication once it IS DONE it looks so simple and easy...... very nice.
#84
Fuse 24 Assassin
Fuse 24 Assassin
Another great pic... this is the cutaway of an intake manifold on an Aston Martin V8 Vantage.
Take careful notice of the tapering of each runner.
#85
note how the rectangular shape twists 90 degrees from the top to the bottom wonder what the port shape and size is ?? Quite a nice piece of work there....and very short pistons for lightweight. No wonder it can spin up so well. I rather enjoyed driving it but never really punched it hard.
#86
Rainman
the key is equalizing (or as close as you can) runner length so they all tune to your high RPM target, for peak power gains.
S4 has a mix of long and short runners to broaden the curve...
find the RPM your cams make peak power, and set runner length accordingly.
#87
Former Sponsor
As a point of order, in another thread where Kibort (the consummate expert on all things 928) appears to be running amuck.
Again.
Apparently, from what I can gather, Kibort is altering what I said about an intake system being both difficult and expensive to produce into me not building one, at all.
Nothing is farther from the truth.
I am full scale production, with Hans's extremely skilled help (and patience), and fully intend to have a production version of my prototype intake, which I tested on a 6.5 liter and a 5.0 liter 928 engine making impressive power output gains ready for use by summertime.
This intake will have runner sizes and plenum volumes that should make it suitable for both 5.0 and 5.4 engines in stock form, as well as high performance applications.
Earlier in this thread, I made a post about this being an expensive undertaking. That is still true. I'm going to have a huge amount of time and money invested (50K?) in this effort. I've got 3 or 4 people that will buy a manifold, for sure (none of those people are Kibort, BTW.)
Not exactly a sound financial basis....
So, the point I was making still remains....this will be an incredibly difficult effort to ever break financially even on.....for the tiny 928 market.
Regardless, I need this manifold for my own purposes, which is why I chose to continue with this development.
Again.
#88
Fuse 24 Assassin
Fuse 24 Assassin
Any luck for sourcing a company to do injection molds and a jig/template? I remember you said it was very costly, but at least if the demand is HOPEFULLY there, a polymer version can be available for street operated cars.
#89
thats exactly my point... its not worth your time... (your words), and those words confirmed below. never said you didnt build one.. quite the contrary... you have one on the stroker and i would LOVE to see that made again, even if done with lower cost techniques. you didnt say( or maybe i didnt see this) that you were in full scale production!
so to help us (928ers) out, what do you think is the best way to get an intake on the 928S4? lets not make this personal.. its just a question? can we use /buy your technology to get this done?
by the way... did my words hurt you? i have no beef with you Greg.. I would always be willing to buy that intake if you wanted to sell me one, with no strings attached. dont go School-Girl on me. you know i would get the best use out of it too!
Again.
Again.
#90
the vantage doesnt have the cool pistons of the model...they look as ive captured below. stuff looks like stock porsche stuff. and the familiar girtle of how the crank bolts in...very 928ish
maybe the model was a new version of the V8 vantage engine, but it certainly is not the one you or i have driven. (you with your daughters 4.3 liter 2006-7)
also Jim, the vantage is like a stroker stroke! 91mm stroke!! (91mm bore) on the 4.7L, BUT, your daughters is a 89mm bore with a 86mm stroke... still near stroker rod angles!! not a high rever like ours can be !
howabout 2 plenums with a balancing port, and a 944TB (55mm) on each?
