928 Forum 1978-1995
Sponsored by: 928 Specialists
rear drag link replacement
Old Feb 6, 2016 | 01:06 PM
jwillman's Avatar
jwillman
Default rear drag link replacement
Have to replace rear drag links. Looks straight forward and I see nothing in the WSM.
Any gotchas?
Old Feb 6, 2016 | 01:19 PM
James Bailey's Avatar
James Bailey
Not sure what you are talking about ??? 928s do not have drag links as such. Possibly rear sway bar drop links ?
Old Feb 6, 2016 | 03:14 PM
Kevin in Atlanta's Avatar
Kevin in Atlanta
Rear lower sway bar links that towing companies love to use to move our cars while bending them in the process. 928 International offers these new now.
Old Feb 6, 2016 | 04:42 PM
jwillman's Avatar
jwillman
Yes, sway bar drop links. One is broken at the weld at the upper bushing so replacing both.
Looks like as simple as just taking gout bolts and reinstall new units.
Any shifting when removing making alignment of the through bolt a challenge?
Old Feb 6, 2016 | 04:47 PM
Kevin in Atlanta
Simple to replace. Unbolt and bolt.
Old Feb 6, 2016 | 04:57 PM
UKKid35's Avatar
UKKid35
IITROR - Installation Is the Reverse of Removal
Many years ago before Rennlist we only had Haynes Manuals, which always said IITROR.
What the hell? The only thing worth knowing is how to install!
Taking apart a new car, taking a few photos, and pretending that you reassembled it was the ultimate lie.
Old Feb 6, 2016 | 05:00 PM
GlenL's Avatar
GlenL
Lift both sides at the same time or the anti-sway bar will be loaded up. Or do not lift at all.
Old Feb 8, 2016 | 03:41 PM
karl ruiter's Avatar
karl ruiter
Carl makes cool looking adjustable ones. I have no need to adjust, but I had to replace and I like the look.
Old Feb 8, 2016 | 03:46 PM
GlenL's Avatar
GlenL
I just get 10mm rod ends and threaded rod and make my own. I'd like to get some aluminum bar stock and make a beefier middle...but I'm too lazy.
