928 Forum 1978-1995
Sponsored by: 928 Specialists
Exhaust Spitting Black Carbon?
Old 01-10-2016, 03:13 PM
jerybak
jerybak's Avatar
Default Exhaust Spitting Black Carbon?
Noticed this the other day on my floor, closed the little garage door behind the shark & goosed her up a little and inspected the rear area and found this.
Old 01-10-2016, 03:33 PM
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,318 Likes on 499 Posts
Curious to know as my car does this too.
Running too rich maybe?
But why?
atb
atb's Avatar
Might need an ECU reset. Disconnect battery for a bit, reconnect, drive like you stole it.
Old 01-10-2016, 04:19 PM
SeanR
SeanR's Avatar
Condensation in your exhaust system being blown out. Not anything to worry about.
Old 01-10-2016, 04:30 PM
Ducman82
Ducman82's Avatar
^^^^^^ yup!
Old 01-10-2016, 04:43 PM
Bertrand Daoust
Thanks guys!
Old 01-10-2016, 08:38 PM
jerybak
jerybak's Avatar
Super, guess I will now clean the garage door & not goose it with it closed ... Lol
Thx
Old 01-10-2016, 08:52 PM
jtrygstad
jtrygstad's Avatar
I have had the same problem - still do sometimes. Sean called it right.
However, when I got the GT, it had an RMB. My wife was upset with it puking black soot on our new concrete driveway. So I told her the rear muffler was missing (not trapping soot) and that a Lomas exhaust system would cure it.
Old 01-11-2016, 04:07 PM
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
Could be a tad rich if Ken's chips and injectors are in there too, although unlikely to be the case. Looks normal to me.
Old 01-11-2016, 04:26 PM
John Speake
John Speake's Avatar
Was the engine cold or at normal working temperature ? If the former then the mixture is usually over rich during the warm up sequence.
Old 01-11-2016, 04:36 PM
jerybak
jerybak's Avatar
I am running ken's ignition chip only currently as I just got the design II 24lb injectors from roger. Also I didn't want to change everything at once if an issue presented after the ignition chip, new plugs, fuel lines, plugs wires, X pipe, etc...
I am planning on installing the fuel chip and the injectors very soon. I am not sure when it spits the black muck. I will check tonight when I get home on a warm engine and a cool and see what is produced.
Old 01-11-2016, 04:49 PM
GregBBRD
Former Sponsor
GregBBRD's Avatar
Received 2,476 Likes on 1,468 Posts
So you are running the additional timing without the additonal fuel that is needed to cover the additional timing?
I'm hoping Ken did not suggest this as an alternative....
Old 01-11-2016, 05:17 PM
jerybak
jerybak's Avatar
I am pretty sure I was told I could run the EZ chip in an S4 car without having to bump the injectors to 24lb, and that I should hold off on the LH until I install the 24lb injectors.
I just reviewed Ken's website to verify, it states the below:
Required EZ only:
- S4 camshafts
- Idle and WOT inputs must function
Required EZ+LH:
- S4 camshafts
- MAF screens installed
- O2 sensor, IE. no ROW no-cat
- 24# injectors - Bosch design II (special o-ring)
Did I miss understand something? Or did I screw something up?
Old 01-11-2016, 05:44 PM
jerybak
jerybak's Avatar
Also found this on the LiftBars Site...
If having a mechanic install the chip(s), purchasing the EZ chip only is recommended.
Issues related to the required 24# injector upgrade often take many hours to sort out.
I am missing something?
Old 01-11-2016, 05:45 PM
Mongo
Fuse 24 Assassin
Mongo's Avatar
I thought there were 2 versions of that EZ chip:
- One that can be ran with 24lb injectors, Bosch 7992 spark plugs, which are colder, and must be run with the LH chip.
- One that is tuned for the factory 19lb injectors only.
Quick Reply: Exhaust Spitting Black Carbon?
