928 Forum 1978-1995
Sponsored by: 928 Specialists
Cross Brace Alternative
Old 10-21-2015, 05:03 PM
  #31
mark kibort
mark kibort's Avatar
Originally Posted by Ducman82
i dont see much a difference. the square tubing "theoretically" would work better twisting bu, . any twisting over that long of a span, would happen either way. then, that much a a twist in that brace would be the least of your concerns. thous little bolts are the same diameter and looks to be height while comprised. slots look the same. so if you think they are an issue, porsche sure did not. looks like the would match up fine with the stock unit. compression and extension are likewise not much of an issue, being when tightened, its one solid rod.
i wasnt talking about rotational twisting of the brace, but twisting of the frame so one side is lowering and the other is raising... that would be a moment at the bolt area.
one thing to note, is that if there is bending of the stock bar, wouldnt it becaused by just jacking the car up? thats much more force than can be applied by the car pulling lateral gs, right?
for that purpose alone, its a valued investment, plus it looks great.
Old 10-22-2015, 08:42 AM
  #32
toofast928
toofast928's Avatar
Hmmm.... Hood gap adjuster! Nice!
So can the fenders be pulled in 1-2 mm to close the hood to fender gap?
Old 02-17-2016, 12:11 AM
  #33
toofast928
toofast928's Avatar
Thread bump.
Hans needs a show of hands for a Cross Brace group buy.
I'm in for one.
Old 02-17-2016, 12:13 AM
  #34
Ducman82
Ducman82's Avatar
id be down
Old 02-17-2016, 01:55 AM
  #35
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Hans:
Of course I want one..but what if you made the bolt down plate to fill that "look at me "gap to the fender?
Old 02-17-2016, 09:23 AM
  #36
jetson8859
jetson8859's Avatar
Add me to the list
Old 02-17-2016, 09:50 AM
  #37
CJ8 2 928
CJ8 2 928's Avatar
Hans looks good as all your work. Is the Jump Post Cover next in line for you to build? :-))
Old 02-17-2016, 11:06 AM
  #38
GlenL
GlenL's Avatar
I'm set for crossbars.
Just curious if you kept the slots in the plates. And, if so, what those are for considering the rod is threaded.
Old 02-17-2016, 12:52 PM
  #39
hans14914
hans14914's Avatar
Glen,
The tabs in the fenders aren't necessarily square. Depending if you want the brace and tabs to be perpendicular to the centerline of the car, you may need that adjustment. If you look at the factory bar, they are also slotted for that reason.
Old 02-17-2016, 03:27 PM
  #40
GlenL
GlenL's Avatar
The spacing between the pairs of bolts on each side will be consistent. The rod-ends and threads will compensate for all other issues.
Old 02-17-2016, 06:57 PM
  #41
Tom in Austin
Tom in Austin's Avatar
Another great idea. BTW, sure look forward to posts about the first projects using the manifold 'starter kits'
Old 02-18-2016, 10:43 PM
  #42
toofast928
toofast928's Avatar
Bump for more crossbrace wanters
Old 02-18-2016, 10:59 PM
  #43
FREAKINHEAT
FREAKINHEAT's Avatar
I may be down for two if fit and finish is spot on.
Old 09-28-2016, 02:34 PM
  #44
hans14914
hans14914's Avatar
I finally got around to having a batch of these made. All the structural components are anodized black 6061, and the hardware is stainless. The standard brace is 620mm long, and allows for minor adjustments. If severe preload/adjustment is required for any reason, a narrower 610mm link can be provided.
Old 09-28-2016, 02:42 PM
  #45
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,206 Likes on 1,245 Posts
Nice work Hans!!!!
Quick Reply: Cross Brace Alternative
