Ignition key
Wondering if anyone can help I have a 85 928 one day out of the blue I put the key in the ignition and it won't turn. The only way now to start the car is keep giggling the key til it catches and turns. I only have one key so I'm not sure if it's the key or the cylinder my help would be appreciated.
Does the key turn in the doors and hatch ok? That would make the key less likely as the problem.
Ignition locks are available from the usual suspects, I think. Getting one that matches your current lock may be a bit of work. Alternatively, have the new cylinder re-keyed.
New keys are available, the suggested vendor is "Keys for Classics" in Australia. A search will give you what you need to know.
Basic Sponsor
Ignition Switch - electrical part at the rear of the lock.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Chronic Tool Dropper
So immediately or sooner, while the key still works the tumblers, extract the old lock from the column and have it serviced or replaced. Removing the old lock without a working key is, um, much more destructive.
The "solution" may be as easy as some lock lubrication to free up a sticking pin or two. Locks typically want a dry lubricant, so common stuff like WD-40 is not an option. It dries in there and gums things up even worse.
While local locksmiths may not be able to make duplicate 928 keys, better ones will give you guidance, and some assistance if you need it. If your fingers and eyes aren't as good as they used to be (as mine tend to be), you can usually save money by investing early in expert help.
If by chance the ignition switch itself is hanging up and it's not the lock cylinder, you can find out by removing the switch from the back of the lock.
Also -- The lock will be stiff to unlock if there's preload on the steering. At least mine can be. Try moving the wheel slightly left and right as you first turn the key. It it suddenly "frees up" the problem may be in the column locking pin rather than the lock cylinder itself.
Electron Wrangler
Not WD40 unfortunately... eventually that will cause it to gum up as it dries out and collects dust. Some kind of dry graphite lubricant is best. But now you have used WD40 using the graphite lubricant wont work so well... The WD40 initially does a decent job of cleaning - which may have helped ungum whatever was already in there. Before it gums up again perhaps some kind of switch cleaner might better clean out the WD40 residue (at least partially) - and the switch cleaner itself will dry out quickly with no residue, then you can use the graphite lubricant.
Best to ask first before trying stuff.
Alan
Alan
WD-40 is a light oil and some solvent. It tends to gum up the pins in pin-tumbler locks, so it's a poor choice.
Former Sponsor
Dry graphite sticks into that grease, making things worse, not better, in my opinion.
Wurth HHS in the locks of your 928 will soak in where it needs to go. Works miracles.
