1978 5sp #107 just arrived - aka the restoration of Minerva
#121
Archive Gatekeeper
Let the games begin!
#122
It's amazing what a little underside cleaning can do. Look at those blue wheel-wells...nice!
What's up next, mechanical stuff? Looks like the waterpump sprung a leak.
Keep the updates coming.
Brian.
Brian.
#123
More pictures! What does the inside look like?
#125
Archive Gatekeeper
More random survey pictures- William took the car to have the chassis steam cleaned, best money you can spend early in a 928 project:
This car has great bones, love the interior:
Is it possible to install a radiator upside down?
#128
That is funny.. you'd need to install the bleed nipple and drain plug on the wrong corners.. they're separate screw-in parts, so I guess it could be done
(from memory the end tanks are the same on each end, as long as they're both either the non-cooler or oil-cooler types).
#129
Archive Gatekeeper
I'm confused in part because I have seen variations of that green part number sticker on the bottoms of many early radiators, but not on what would have been the top. Maybe it got repaired and the core flipped over? No idea. Will follow up when I have the radiator out.
#130
#131
The Parts Whisperer
#132
#134
Archive Gatekeeper
Dunno what's 'correct' on the underside, especially the early cars.
Did manage to get back out to the garage under cover of darkness this evening, pulled the radiator. Temp gauge is in the right place, so the rad must have been re-tanked at some point and the core flipped.
I don't ever recall seeing a radiator tank losing it's black color- I thought the plastic was black all the way through (?)
Someone didn't exactly sweat the details on crimping all the tabs back down:
#135
The Parts Whisperer
