928 heads on a 944?
Rainman
When I get around to the 928 head (should be picking them up today!) on the 944 engine I will definitely share the results here on Rennlist.
For your car, I suggest just finding a 944 head to directly swap onto the car and everything will work, for sure. You are still fairly new to 944 stuff so stick to the easy option for now. When I get around to the 928 head (should be picking them up today!) on the 944 engine I will definitely share the results here on Rennlist.
that's right... the S2 944 and the 968 are both 104mm. are they both 3 liter too? so , besides the valves being larger in the 968, what is the difference in the piston? I seemed to remember that both could be used in stroker 6.5 L projects. but I forgot the differences.
Former Vendor
Couldn't you just get on CL and find one of the many ragged out 944's that set not selling for under $2000 and offer $750.00 and be ahead of the game?
-Jason
-Jason
928S3 has 35mm intake valves.
928S4/944S/944S2 have 37mm intake
968 has 39mm intake, but the same bore as the 944S2 (104mm)
re:valve sizing, been doing some reading on that based on S3 concerns and found some interesting figures...i think the 35mm will work for my purposes and rpm range.
- honda s2000 (2.0 or 2.2L depending on year) has 36mm valves, sufficient for 8000+rpm and 240hp
- current Ford 5.0 Coyote (5.0L) has 37mm valves, good for 7000rpm, 420-450hp or so.
- 944S2, 3.0L with 37mm valves but a good tune and hot cams, 280whp (https://rennlist.com/forums/944-and-...big-power.html)
- on front corner of 944 head is a tab for coolant to pass through as a recirculating feature, on the 928 heads the tab is there but it is cast shut so no water flows. other coolant/oil passages should be similar between models.
--- this block-off could be desireable for us, as some experiments have been done blocking off this recirculation path on the 944 with a modified gasket, resulting in cooler, more consistent cylinder head coolant temps.
--- along with relocating the thermostat, higher system pressure/pump efficiency.
- 944 2v head is like the 928 Euro 2v stuff.
- 944 doesn't need a water bridge or anything like that - just reuse the 944S coolant parts on the 928S3 head (the coolant outlets on either end of the 928 4v head, where the 928 coolant bridge goes, the 944S has its upper rad hose on one port and the heater core hose on the other)
see some pictures in 1st post of this thread....
https://rennlist.com/forums/944-turb...-question.html
Nope. S2 is a 16 valve motor. Unlike the 928 there was no S4 or anything like that, the S2 is the final iteration of the 944 motor before it went 968.
Rainman
1989 944 had a 2.7l (104mm) 2v engine with 48mm intake and 40mm exhaust.
The 944S was a 2.5 4v engine, heads very similar to the 928S4.
The 944S2 was a 3.0 4v engine. Heads were basically the same as the 944S but modified to fit the 944 3.0 block.
968 head was like the S2 but with 39mm intakes, larger ports, and modified tensioner boss for variocam.
928 cams come out, 944 cams go in.
The regular 944 from 82-88 had the equivalent of 928 euro 2v heads/valves. 45/40 valves. 1989 944 had a 2.7l (104mm) 2v engine with 48mm intake and 40mm exhaust. The 944S was a 2.5 4v engine, heads very similar to the 928S4. The 944S2 was a 3.0 4v engine. Heads were basically the same as the 944S but modified to fit the 944 3.0 block. 968 head was like the S2 but with 39mm intakes, larger ports, and modified tensioner boss for variocam. 928 cams come out, 944 cams go in.
Depends on what pistons are. S3 head works better with 2-valve heads. Compression ratio get to be interesting when '87+ 4-valve heads are mixed with 2-valve pistons.
The 928 S4 head will work on the 944S with the coolest passage drilled out and the rear head addressed because it protrudes out. This is because once it's on the other side of the V-8 it sets back and has to have more meterial to line up the timing belt drive. If you have a 944S and want to fix it without messing around then find another 944S head. A 928 S4 head WILL work if you have to. But the rear of the head will need to be ground down an bit so it doesn't rub the DME wires going thru the firewall. The 928 S3 head is completely different at every side then the 944S head or the 928 S4 head. So far myself and Spencer are going to biuld a 16v turbo engine using the S3 heads. Also the S3 head uses a differant cam cover then all the 944S/S2 928 S4 heads. The seal makes a funny turn at the rear of the cover for the S3 head(rear being on the passanger side now). The 928S4 and 944S share the same valves and all the same features besides the drilling that would be required for the S4 head to mate onto the 944 block (it will still bolt up but this is for coolant purposes). The 928 S3 has a few mm smaller valves as pointed out and there shorter. However Ferrel is a valve company that will make custom S3 exhaust valves that will handle the turbo exhaust for under $65 ea. Not needed if not gong to a turbo. Also if your keeping the car as a N/A then don't use the S3 head. The intake runners are round not oval like the other 16v heads and the exhaust won't bolt up with any 16v exhaust without replacing the flanges on the 944S exhaust pipes. The cumbustion chamber is too big for a high CR needed for the N/A 944S. One thing I did notice in my parts book is that ALL of these head share the same cam followers. And 928 Motorsports sells lightwieght cam followers if one should chose to replace them with lighter parts. As far as the timing assy goes, the 944S bolts right up to all three heads without any issue. The most expensive part isn't the head, or having custom valves made. It's all the 944S timing assy parts! All of the parts! Don't expect to use a 944 2v timing anything on the 944S, not even the black plastic timing belt covers, any of them(it's wider at the top on the 944S. It's best to start with a complete used 944S engine with all the timing goodies regardless if your keeping it N/A or turbo.
Also it's best to ask these questions in our 944 specific posts. I had to do a search after talking to you for this post. Good question. Like to add a few more head facts, the 928 2v heads don't have the water port needed to be mounted to the 944 2.5 block, but the 4v heads do. And 944 S2 and 968 were both 3.0 liter four cylinders with 104mm bore and 88mm stroke. Using 944S Pistons in a 928 I believe drops the piston 2mm in the bore for you 928 guys that want to turbocharge your car. If a 944 enthusiast wanted to use 928 S4 Pistons then they would need purchase 2mm shorter connecting rods(LR has on hand for 944 engines), or offset the crankshaft 2mm shorter stroke and still get custom rods. Not recommended at all, or ever, by anyone.
Rainman
Humboldt - I'm not going to drill out that coolant passage, just going to route the coolant recirculation elsewhere. Some guys in AZ have had success blocking that passage off on the water pump side and putting the thermostat on the return path to the radiator, gives them cooler water temps (since hot water that just passed through the head isn't being recirculated rather than going to the radiator) and higher system pressure (since the pump inlet is not restricted by the t-stat anymore).
Also...If you grind the 944 crank journals to 2" Chevy size, run 5.7" Chevy inline 6 rods with pins drilled to 24mm for the Porsche piston pins, you could run the 928S3 piston in the 944 block with about 3mm of deck clearance and ~7.4:1 compression.
then, why the heck are we not building these euro 5 liter motors for the 928 with the '89 944S heads! 48mm intake valves???? wow, thats substantial, more than going stock US 43mm to euro 45mm!!
