928 Forum 1978-1995
Sponsored by: 928 Specialists
Battery cutoff switch
Old Sep 7, 2015 | 08:35 AM
glmoore0001's Avatar
glmoore0001
Default Battery cutoff switch
I would like to install a battery cutoff switch, more for maintenance purposes than security.
Can anyone give me an example of installation location and the type / brand of switch you used?
Thanks ... Gary
Old Sep 7, 2015 | 09:35 AM
AO's Avatar
AO
Supercharged
Why not just disconnect the ground strap at the back? Some cars have a large "wing" bolt/screw that can be done by hand, while other have just a bolt. If you have the regular hex-bolt, it's simple to swap it with a wing style, or get a plastic piece to convert it.
I believe it's an M8x1.25 bolt. You can get one on Amazon for a few bucks.
JW Winco Glass Filled Nylon Plastic Wing Screw, Threaded Stud, M8 x 1.25 Thread x 20mm Thread Length, 48mm Head Length (Pack of 1): Male Wing *****: Amazon.com: Industrial & Scientific JW Winco Glass Filled Nylon Plastic Wing Screw, Threaded Stud, M8 x 1.25 Thread x 20mm Thread Length, 48mm Head Length (Pack of 1): Male Wing *****: Amazon.com: Industrial & Scientific
Old Sep 7, 2015 | 09:52 AM
glmoore0001
Originally Posted by AO
Why not just disconnect the ground strap at the back? Some cars have a large "wing" bolt/screw that can be done by hand, while other have just a bolt. If you have the regular hex-bolt, it's simple to swap it with a wing style, or get a plastic piece to convert it. [/url]
I am getting ready to change out all 53 relays in the CE.
It was strongly suggested that i replace the relays one at a time and restart/check the systems between relay installs.
Having a cutoff switch should substantially shorten the time involved in that chore.
Do you know of any drawbacks to installing one?
Old Sep 7, 2015 | 09:53 AM
dimi5928's Avatar
dimi5928
Here is a link for this...
https://rennlist.com/forums/928-foru...ff-switch.html
________________
Jimmy
89 s4 Black black
Old Sep 7, 2015 | 09:58 AM
ezdriver's Avatar
ezdriver
Thanks ... Gary
How about using a jumper cable to bridge the battery to the car and simply clip/unclip one of the jumper cable connection? Why add one more electrical component to your car for just a rare use?
Old Sep 7, 2015 | 10:03 AM
glmoore0001
Default Thank you
Thanks for the link.
I had searched but all the topics i found were concerning solid state diconnects for racing.
This is exactly the type of cutoff i was thinking of. Placement near the battery box also. Very helpful.
Old Sep 7, 2015 | 10:04 AM
glmoore0001
This is a good idea also... thank you.
Old Sep 7, 2015 | 10:07 AM
dimi5928's Avatar
dimi5928
Here is more details
Is my next project..
https://rennlist.com/forums/928-foru...ferrerid=42434
_______________
Jimmy
89 s4 Black black
Old Sep 7, 2015 | 11:49 AM
mdkelly1's Avatar
mdkelly1
The usual approach is to mount it behind the tool panel:
File Type: jpg
Old Sep 8, 2015 | 03:31 AM
jpitman2's Avatar
jpitman2
I have heard about the ground wingnut - never seen one. Its also rumoured that the thread is M8x1.25 - mine is 5/16 UNC - check before you plan on changes there. I have a battery isolator as pictured above, and despite being sceptical, it works fine. My charge leads bypass it so I can disconnect the system from the battery, but still charge it easily.
jp 83 Euro S AT 56k
