Coke Car running lean...
#181
go look at the thread.... ive only tried to help here. Brendan posted the insults first starting with the offensive fat guy in the wheelchair picture, which has no place here in my opinion. But you missed that?? that appropriate? that's contributing? whats wrong with you greg?
BTW: i just read all the posts over the last 4 pages and the only one being inappropriate and having a personal attack is BC brendan and you. my posts to him were responses. my interactions with AO , Ken, and others are strictly technical without any personal comments
#182
Inventor
The new filter helped, but that wasn't the smoking gun. With Ken's LH chip, I am solidly in the 14's with an occasional 15 at WOT. Idle and cruise seem okay (makes sense because of the O2 loop), but WOT is still lean.
I put the stock LH back on at I hit low 12's mostly and saw an occasion 11.
BTW, if you haven't already, you should adjust the MAF to 382 ohms to eliminate a variable.
Would be lean. With the S4 FPR it is in the low 12's at WOT with the stock chip which is about what the stock chip and S3 FPR will do at higher rpms (in hot weather).
#183
Yes but it's only mustering up mid 40 psi right now under load. If the S3 regulator gives constant 36-38 psi he should be bang on at high 12's-13.
Still, there HAS to be a reason why this car can't give 55 psi under load with the S4 fpr. Just have to find it.
#184
Unless he changed it, the MAF is set lean of center at 300 ohms. He could probably dial up the CO to make idle and cruise happy but even with the additional effect the CO screw is programmed to have on WOT with the S3.S300s chips it would still be on the lean side.
Getting there! Would be good to record the fuel pressure on the road. I don't put much stock in the effectiveness of the driveway dyno.
Would be lean. With the S4 FPR it is in the low 12's at WOT.
so you think at 50psi at 11:1 and 12:1 , he can put the S3 regulator in and he will be lean? 50psi to 38psi?? I think both of us would agree that most likely, he will be in the high 12s or 13.5 to 1 ,which is the stock spec. I might be wrong, but i don think a 10psi change will do that much here.
it would be an interesting test. also to see if the sytem goes to 38psi based on the new 38psi fuel regulator. if it does, then it points to the S4 regulator as being odd, or some other restrictions that the S4 doesnt have to make the S3 run at 50psi vs the rated 55psi.
#185
in my experience, ive taken the 84 from 13:5 to 12:5 with changing the fuel pressure to 52psi. (max of the regulators) I think that was only about a 10psi change. i havent seen much of a difference with the stroker going from 50psi to 40psi, but it might be drowning from the beginning anyway.
as you say, the curious part is why he isnt getting 55psi. the filter cant cause that, because if it did , you would see big fuel pressure drops at the higher rpm. plus, there would be no change at idle. he has static fuel pressure of 55psi... so why does it go down 10psi when running and no vacuum?
#186
Inventor
S3 FPR is rated at 36 ±3 psi (hot_33-39_cold).
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
1 psi = 2" hg
(Also factor fuel temp and outside air pressure.)
#187
Former Sponsor
Has AO measured the fuel pressure with the vacuum line disconnect, after the new filter got installed?
That would be the data I'd be looking for, before worrying about too much more.
Like Ken says, the "vacuum" fuel pressure of 45 PSI is in the ballpark.
#188
Former Sponsor
The angle of the C/V joints tearing the boots?
#189
Actual WOT fuel pressure is unknown after the fuel filter change. Only that idle is 45 psi with vacuum.
S3 FPR is rated at 36 ±3 psi (hot_33-39_cold).![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
Because...that's what 20" hg of vacuum does, independent of your 'observations'.
1 psi = 2" hg
1 psi = 2" hg
now, as far as vacuum on the Fuel regulator, just because you have 17" Hg (not 20"Hg
help me understand what you are thinking.
the video clearly shows WOT pressurue of about 43-44psi max and off and idle with vacuum is around 40psi. notice off throttle it falls further, but thats because the vacuum willl spike at near 25-27" HG off throttle from moderate rpm. still only about 6-7psi diff at that vacuum.
#191
And yes, adjusting the MAF pot can make a pretty big difference to the mixtures - Ken's point just above about setting the potentiometer in the MAF to the mid-point of 382ohms is a good start. Right now at AO's 300ohms, the ECU is reducing the fuelling because its been "calibrated" to an overperforming MAF.
The ideal would be to adjust the MAF signal input using the pot and about $3 worth of bits (crocodile clips, LED, 750ohm resistor, bit of wire), but centering the pot as a start would certainly help.
Only?
#193
Its not perfect with the stock chip, because he's not running the stock fuel pressure. The stock chip with stock fuel pressure would be lean too.
Only?
Only?
i was under the impression that the MAF adjustments are really more for part throttle operation
it will be interesting to see if the changes he saw with fuel pressure after the filter was changed, changes his AFRs. my guess is that they wont.
and as far as your "only ? " post..... yes, Ken was pointing to a direct relation of manikld pressure and fuel pressure reduction and that is not the case. its not 10 psi drop of fuel pressure with the vacuum attached... its more like 5 and for good reason.
#194
Inventor
Any news?
#195
Supercharged
Nope. I've been traveling for work the past couple weeks. Where I left it last, I had installed a permanent WBO2, and the stock LH chip. WOT AFRs were in the mid 11s, so it's safe.
The only things I have not touched are the injectors and the front fuel damper. The damper is the only thing I can reasonably think of that would be a bottleneck as the fuel comes in through that and then distributes to the fuel rails from there.
I probably won't do anything further this year unless I can get my hands on a spare damper (cheaply).
I'm on a waitlist for a track day this Thursday, but then it will likely be going away for the long winter nap.
