928 Forum 1978-1995
Sponsored by: 928 Specialists
Piston Diameter
Old Sep 2, 2015 | 03:37 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
Default Piston Diameter
Any one know the bore diameter for an M28/43 (85-86 auto 5L) ?
I'm playing around with the knock sensor settings on my Mega Squirt and I'm trying to work out the resonance frequency of the bores......
Old Sep 2, 2015 | 03:48 PM
mark kibort's Avatar
mark kibort
the pistons were exactly 100m... the gap was only a few thou. to the bore.
Old Sep 2, 2015 | 05:01 PM
dr bob's Avatar
dr bob
Chronic Tool Dropper
Let me know how you do that calc. In my wayback history, I started by using a spectrum analyzer connected to the piezo sensors to try to identify the signature of knocking, while working to isolate that from piston slap and other normal combustion noises. Since the knocking occured only when piston was at or near TDC, the noises I was looking for started out in the head. Except for RPM multiples, which obviously move around, there wasn't a specific frequency signature that I could identify with knocking. In the end there was some filtering, but my controller was looking at peak amplitude spikes vs. a moving average as best indicator.
I'm sure the science has improved. And while I worked with rocket scientists a lot, I didn't have one on call to verify my assumptions.
Old Sep 2, 2015 | 05:23 PM
atb's Avatar
atb
That would be a few "ten" thou. to the bore (actually about 8). We're not talking small block chevy's here.
I believe the bore is exactly 100mm, and its the piston that is undersize by .02mm.
Old Sep 2, 2015 | 09:25 PM
LT Texan's Avatar
LT Texan
Yes, the bore would be 100mm and the piston smaller.
Old Sep 2, 2015 | 10:04 PM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
Depends where you measure the pistons, they're not round.
S3 and S4 bores are 100.0, 100.01 or 100.02, and get group 0,1, or 2 pistons.
These are S4 pistons, group 1, not S3, but anyway:
Vertically, halfway down the skirt (62 mm below the crown), they're 100.00 mm (probably actually 99.99):
But they're only 99.41 mm wide at the same level
Vertically, above the top compression ring, they're only 99.47 mm:
And horizontally, above the top ring, 99.38 mm:
Old Sep 2, 2015 | 10:35 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
Are you saying they were oval from the factory?
Old Sep 2, 2015 | 11:40 PM
Rob Edwards
Archive Gatekeeper
Nah, these particular pistons had ~100K miles on them. They must be round when new, but that's how they wear with use.
Here's a used 968 piston from the last Zombie motor, just measured 'cuz I'm curious- It's also ovalled, at least at the top, adjacent to the crown:
Height 103.49:
Width 103.26:
I also measured some new pistons that may be going into the next Zombie motor- both are round.
JE: Height: 102.86
Width: 102.87
Old Sep 3, 2015 | 05:14 AM
Strosek Ultra's Avatar
Strosek Ultra
In order to compensate for heat expansion, all kind of pistons are shaped oval and conical (taper). Racing pistons much more than others. I did remeasure the piston shown here and the diameter at the very top is 99.42mm and below the oil ring 99.90mm. The other two dimensions are correct. Can´t understand why I measured incorrectly in the first place.
The aluminum heat expansion rate is high, the figures were taken at a temperature of 66F. If the figures had been taken at a higher temperature like 100F the piston dimensions would show an expansion by appr. 4,5/100 of a millimeter.
The 928 pistons are somewhat barrel-shaped, circular at the ring area but oval below the rings.
Åke
File Type: jpg
Old Sep 3, 2015 | 05:15 AM
Vilhuer's Avatar
Vilhuer
They are smaller on top to allow heat expansion.
Old Sep 3, 2015 | 05:31 AM
Strosek Ultra
Rob, I find it difficult to measure this kind of small tolerances using a digital caliper with great accuracy.
Using a micrometer will increase the accuracy quite a lot. However a digital caliper is probably the only tool we have available for the measuring of ring groove bottom diameters.
http://www.goodson.com/Micrometers-set/
Åke
Old Sep 3, 2015 | 11:35 AM
Rob Edwards
Archive Gatekeeper
Hi Åke-
Yes, I'm sure every good machinist has a small twinge of chest pain when they see pictures of my cheapass caliper, pretending to do precision measurement.
That's a pretty good price on that Goodson mic set- I troll Ebay on a semi-regular basis looking for a good Mituotoyo 0-6" set (and a bore gauge...), but they're expensive.
Old Sep 3, 2015 | 12:05 PM
Strosek Ultra
Originally Posted by Rob Edwards
Hi Åke-
Rob, go for the micrometer set if you find the price good. This is a lifetime investment and I do not think your interest in powerful engines ends when you get older. Well you need bore gauges for the measuring of inside diameters too.
http://www.goodson.com/FBG-7-FBG-146...r-Bore-Gauges/
If you have the micrometer set you can do good with a set of telescoping gages which is only a fraction of the money.
http://www.ebay.com/bhp/telescoping-gauge
For the measuring of valve guide inside diameters this is what you need.
http://www.ebay.com/bhp/small-hole-gage
Åke
Old Sep 3, 2015 | 01:56 PM
mark kibort
thats right!!!! i forgot.. the bores are 100mm, but the pistons are not even round! (and a few tenths smaller) (although my stroker had a few thou gap, not the porsche gap. )
Old Sep 3, 2015 | 03:04 PM
Strosek Ultra
The piston to cylinder clearance is between the largest diameter measured on the piston and the cylinder diameter. Next time you have your stroker race engine apart, it would be very interesting if someone with great precision could measure the cylinder bores at six different points, at the top, in the middle and at the bottom of the bores parallel with the wrist pin and in ninety degrees to the wrist pin. I am sure you will find a certain out of round and taper in every cylinder.
Åke
