Leaking radiator - repairable or replace?
Hi. My ,87 s4 auto - RHD have sprung a leak.
Coolant bubbles out from the top left hand corner (when facing the car).
Is this a common symptom with a known source and fix? (He asks hopefully!)
This is a common problem. The leak is likely from the joint between the aluminum core and the plastic end tank or a crack in the end tank. You can have a radiator shop replace the plastic end tank and gasket seal, but they need to be familiar with removing plastic end tanks and reinstalling them without breaking off the metal tabs that hold the plastic tank to the core. I believe there is a write up here on how to DIY the gasket replacement if you search around a bit and you are comfortable to DIY this repair. It's a good idea to read the procedure even if you're going to have a shop do it. That way you'll be familiar with the process and can ask the right questions and tell if the shop is competent to do the repair correctly. Either way you will want to source your own parts. If the shop can source the parts they will likely overcharge you.
Most shops don't repair radiators. They just replace them, so be sure to talk with the tech doing the work to ensure that he's done this type of repair before.
I had a leaking oil cooler inside one of the end tanks. I was able to find a good used oil cooler and install it in a new end tank then have a shop install the end tank with a new gasket. The repaired radiator is leak free and the cost was a fraction of buying a used radiator.
DO it this way:
https://rennlist.com/forums/diy-subm...king-tabs.html
I'm hoping to get permission to add the pics back, or at least a pdf with the pics - basic story is pry up the whole edge, rather than individual tabs.. then clamp with new tank in place, and tap edge back into place (thus pushing the tabs down again) with a hammer.
edit: Also, its most likely the leak is from a crack in the plastic end tank, and not the gasket. Just replace the whole end tank and be done.. instead of doing what I di and replacing just the gasket only to find it still leaked, and having to do it again
Wow haven't seen that old thread in awhile ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Yes my way involves fabrication and is great if you have broken tabs or just don't want to deform the edge of the core. (by the way the radiator pictured in my post is still in service w/o leaking on my 85.
I have also used the edge bending method on two others with also good results, one thing I noticed is start with a small screwdriver and go round and round then move up to a larger prying tool.
Don't try to get it apart in one shot, also you do not need complete clearance, just enough to get the tank out, less bending the better
(I also coat the new seal w/ some water pump grade gasket sealant).
The main thing is to get the End tank off and inspect the core, if it's not clean/unblocked, get a new Rad.
Dave K
Dave K
Or you can order an aluminum replacement radiator from 928 Motorsports or 928 International for a fraction of a Behr, if you can find one.
Ive had one in my 82 for 18 months and the cooling qualities are much higher than the old Behr. But in fairness, the Behr was 32 years old.
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
You can only repair once. The second time around the metal tabs break. When that happens, go all aluminum.
I am dreading this day again....
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Not that way.. you'll break tabs.
DO it this way:
DO it this way:
