928 Forum 1978-1995
Sponsored by: 928 Specialists
928 gear ratios.
Old 09-07-2003, 07:36 PM
ViribusUnits
ViribusUnits's Avatar
Default 928 gear ratios.
Does anyone know what the first gear ratios are for the 78-82 928s?
I'm fairly sure they're diffrent, but not 100%
I've noticed that the first gear of my 83 is realy low, at 4.something:1! That offsets the high final drive. Hum...
I was curious about the earler cars with the 2.75 final drive.
Thanks.
Old 09-07-2003, 07:57 PM
Lizard928
Lizard928's Avatar
http://www.928registry.org/menu.htm
Old 09-07-2003, 10:46 PM
ViribusUnits
Thanks, but thats no help, unforchantly.
I know what the final drive ratios are. I'm looking for the first gear ratios. This away I can work out the over all ratios for first gear.
I'm faily sure it's in the back of an 78-82 owners mannual, but then again, maybe not.
Old 09-07-2003, 11:00 PM
V-Fib
We had a choice?
V-Fib's Avatar
V.U. probably won't help with your 83, but the 78-80 MY are
Manual Trans
1st- 3.6010
2nd- 2.4646
3rd- 1.8194
4th- 1.3433
5th- 1.0000
Auto Trans
1st- 2.306
2nd- 1.460
3rd- 1.000
Anthony Tate
79/928 Silver Metallic
Old 09-08-2003, 10:12 AM
Old & New
Old & New's Avatar
G28.05 3.6010
G28.07 3.7645
G28.08 4.2705
Old 09-08-2003, 06:06 PM
ViribusUnits
Exactly want I wanted. Thanks.
I've got the infor for my 83, it's in my owner's mannual.
I noticed that when Porsche switched to the realy high 2.2 final drive, they switched to a REALY low 1st gear, giveing a very similer over all gearing ratio for first gear. Hum...
See, I figure that Porsche didn't put an over drive transmittion on these cars. As a result, they had to put a realy high final drive to meet mpg expectations. To compensate, they put a realy low first gear in, resulting in a higher over all 5th gear, but a similer 1st gear.
does this make any sence?
Old 09-08-2003, 06:39 PM
Jack '84 928s
Jack '84 928s's Avatar
I think im sure the older 3ps trannys had the 2.75s in them. I bet it would help alot to swap that in.
Old 09-08-2003, 06:54 PM
ViribusUnits
Your right, the early ones have the 2.75:1 ratio.
So, with a first gear of 3.6 and a final drive of 2.75, the over all ratio is 9.9:1.
The 83s have a 2.2:1 final drive, and a 4.1:1 first gear. The over all ratio for first gear is 9:1.
So, if you put an early rear end in an 83, you get an over all ratio of 11.5:1.
That sounds intersting no? Thats about the same ratio that 4.6l mustangs get when they have like a 3.77 rear end...
Quick Reply: 928 gear ratios.
