Most of you know that the engine rubber fuel lines are often NLA (no longer available) from Porsche. And that your engine fuel lines are old, cracked, and brittle due to their age and the harsh environment they live in.
Fortunately, they are not hard to service.
We have been selling the correct metric high pressure fuel lines for a number of years that allows you to replace yours... one meter of it is only $15 and that's enough to do all the above-your-engine fuel lines and still have some left over. Here is a link:
To make it even easier for the do-it-yourself-er, I have sourced the correct Oetiker clamps and the crimping tool that you need. The tool and 25 clamps are less than $28. Here is a link:
This is typical of the steel-and-rubber fuel line that you will find on your Porsche.
The steel elements are fine, but the rubber section needs to be replaced.
FLR1
By rebuilding the fuel line from your car, not only will you save money compared to buying new, but you are also assured that it will have the correct connections to match your car.
FLR2
Place the crimping tool over the ear of the clamp and squeeze. It is not necessary or intended that you will crush the ear all the way until it touches itself.
FLR10
A properly installed Oetiker clamp. Note the gap between the two sides of the ear. This clamp will expand and contract with temperature changes in the hose, like we want it to.
FLR11
Looks like what we have "all" been doing for the last 10 years - cue Greg in 1,2,3
Seriously does not look like the same hose Porsche uses. Does your hose have the correct polyamide veneer for use with barbed fittings?
This hose in made in Germany and OEM for Porsche®, BMW, Mercedes-Benz and Audi. It is 7.5mm metric in size and an exact fit for your Porsche® 928 fuel system.
Specifications: ID 7.5mm, OD 13.5mm; Working Pressure: 145 psi or 10 bar; Bursting Pressure: 435 psi or 30 bar; Temperature Range: -22F to 194F; abrasion-resistant cover; approved for gasoline, gasoline with 10% ethanol, diesel fuel, water, air, and heating oil.
