HP + TQ for 16v heads and 5.0 block
#61
what 4.5 liter? CIS? anyway the best you can do for relatively cheap might be the headers.... I have a cat that plugs into the devek level 1 headers. almost new . only used it for smog one time. for sale! then, you can use your stock exhuast system. look for about 10-12 hp.
Thx for the info I will have to check into headers and exhaust and cat.
Btw whats a CIS?
#62
CIS or Continuous Injection System is a fuel injection system that was developed by Bosch and is used in some of the early 928s. It is also known as K-Jetronic.
Since your car is a 4.5 it will either be running on a K-Jetronic or L-Jetronic fuel injection system. The later year 928s all used LH-Jetronic. The easiest way to tell at a glance which system your car is using is to look at the injectors. K-jet injectors each have an individual fuel line coming from a fuel distributor and with l-jet you have two fuel rails each connecting to four injectors above each cylinder bank.
Google is your friend. All of this information could have easily been found by with a couple of quick searches.
#63
First get it running 100% in stock form. All 928's share a considerable amount of low end torque with differences "mostly" at higher RPM. If your car has grunt issues, something is likely wrong, unless its an automatic.
#64
I am contemplating this for my 83 928 S R.O.W. since it dropped a valve destroying a few bits.....
Can the S4 be used as well or just the 85/86 5.0 litre?
Adam
Adam
#68
I don't know exactly what your goal is. I will be putting together a number of two valve engines of varying capacities. They will make big power over a standard engine. They also have a lot of reconditioned and new parts. The cylinder heads have had a lot of development. I intend to dyno test the engines also. If you're interested drop me a line.
#69
Hi Adam,
But I do so am looking at the most "economical way! I don't know where you are located, so freight or otherwise may come into it.
#70
Mate the freight would be tiny compared to the cost of the engine. Most standard rebuilds in Australia at specialist repairers are $20K (Fitted, two to three days labour included) on average. That is a standard rebuild not run on the dyno etc. Not with ported heads, increased compression and custom manifolds etc. I'm in NSW.
#71
I intend to rebuild it myself, saving a large chunk of that $20k! Unless I can find a good used one that just needs minor things. I don't need or want extra hp, but if it costs the same to do a 5.0 litre hybrid then I will strongly consider it.
#72
I hope you can now if you didn't already now the difference between an expertly rebuilt engine and a home job. They cost different amounts of money.......
#73
Sorry to ask again, just limited supply of engines here in Aus
Adam
