HP + TQ for 16v heads and 5.0 block
https://rennlist.com/forums/928-foru...-thread-6.html
If you have a look from the top of the page and then continue downwards, you will see some of the changes I have made on the most basic of the four engines I am building, it is a 5.0 litre. The various tests are in different versions of the same capacity but minor changes like custom cams, custom intake manifold, or changes to ignition timing etc. this was before I had a aftermarket ecu that was able to tune precisely the air fuel ratio and ignition timing. So it is not fine tuned in these guises.
The dyno numbers would equate to just under 400 HP, I suspect 390 HP as other cars are factory rated around that number and get similar or slightly less rwhp numbers. There is a lot of devil in the detail to achieve these results and you can easily get less. I will be putting another engine together shortly so if you are interested keep an eye out. That engine though will use 104 mm pistons and standard stroke.
I should add that the engine is being rebuilt with larger 48 mm Porsche valves from the 2.7 litre 944 and has increased head flow, I really think the head flow held it back and with that aspect improved in association with better tuning it will certainly be over 400 HP with very good torque. You could use many different aftermarket valves to do the same as I did with the Porsche valves.
Correction, 310 rwhp. I never did polish off the top end of the tune. For every 1 degree advancement in timing we were getting 1.2 more hours. But I ran out of dyno time and have been to busy. I am adding knock sensors so we shall see what that changes
Typical for whats called a Euro hybrid, stock Euro top end on a stock US 85/86 bottom is 285 rwhp, its been done many times with fairly consistent results.
Ive built 3 of these.... all still runing today. the Ljet makes 290 at the rear wheels (as compared to the 200 to 220baseline for a stock US 4.7L. one we did with CIS, and it made over 310rwhp. (torque was in the 290ish range)
all euro heads, and intake along with headers.
Mk
Mk
For an '81 5-spd with a 4.5L I am shopping a couple of ideas for power upgrade
1) buy a bolt-on supercharger or
2) toss the 4.5 for a 5.0 which will also mean some head/cam work will have to be done
I think costs are roughly the same between 1 and 2 and finished power will be similar.
For those of you who did the 5.0 swap why not a supercharger instead?
