HP + TQ for 16v heads and 5.0 block
Cost me , if I remember right, 250? To get the Pistons fly cut for the 2v heads. All the rest of the "cost" was maintenance and rebuild. Nothing else really special needed. Finding the euro parts is the fun part of the build. I got a ridiculously good deal from a gentleman in England. Heads, cams, towers, i take...... All shipped for 700 bucks. I paid more for shipping than I did for the parts!!
For an '81 5-spd with a 4.5L I am shopping a couple of ideas for power upgrade
1) buy a bolt-on supercharger or
2) toss the 4.5 for a 5.0 which will also mean some head/cam work will have to be done
I think costs are roughly the same between 1 and 2 and finished power will be similar.
For those of you who did the 5.0 swap why not a supercharger instead?
I am not knocking forced induction, I am just saying fix what is there first before trying to up the ante, the 5.0 litre approach is also simpler in terms of tuning etc, while your in there please change to a later type of injector and give yourself a compression bump.
My setup with ported heads, 48mm intake valves, sports camshafts, special valve springs, Dellorto 48mm carbs and intake would do nicely on a 5.0L block.
See post #22: https://rennlist.com/forums/928-foru...e-money-2.html
See post #27: https://rennlist.com/forums/928-foru...e-money-2.html
Åke
Åke
If you are referring to the injectors, I was using 28 lb 4 spray hole GM injectors made by Bosch. I bought slightly larger EV14 style for the 104 mm bore engine as they have much lighter internal components, maybe something like that in a injector around 24 to 26 lb as long as you can tune it.
I think costs are roughly the same between s/c and 5.0 swap and finished power will be similar. I have read a basic s/c kit will add up to 100hp and by the looks of it a 5.0 swap is about the same with proper heads, cams, intake.
New s/c is $6k and $8k a used kit will be less. I will do the install.
the 5.0 block will be up to $3000 including purchase, shipping, refresh plus heads, cam and new everything when you put it together (belt, h2o pump, headers, exhaust, injectors, tuning), yank the 4.5 and install 5.0. I figure $6-$8k. I will pay for the install.
I don't have itemized costs just a guestimate. I have about an hour or two of research. Decided to post rennlist with questions.
Basic Site Sponsor
Basic Site Sponsor
As usual, some of the dyno numbers being tossed around here are just plain silly.
You have to be realistic/use your head.
A stock, good running '85/'86 Euro with 80,000+ miles will make about 275rwhp +/- 10hp.
Why would anyone think that simply raising the displacement 300cc raise the rwhp output 35-45 horsepower, with no other changes?
Simply not going to happen. Totally Dreamland stuff.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
Mine had some changes apparently , the worst of which was converting a non-interference motor into an interference one. But I can live with that "mod".
Your motor is proof that pistons don't have to be flycut (I've viewed them with an endoscope), and that when you don't flycut, it then becomes an interference motor (which I've also physically confirmed). It would be interesting to know what your compression ratio is ... I suspect it might be up there.
