Wanted GTS Crankshaft & Pistons
Basic Sponsor
Hi Houssam,
I have nothing used but I do know they still have 22 GTS cranks in Stuttgart at the knock down price of $8500 each.
Pistons are slim pickings - they have 6 of the 100mm Grp2 at $600 each. They probably forgot a 928 has 8 cylinders.
Mark at 928 Int. is your best bet for used or new old stock.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Hi Roger,
I am making the deal for the pistons with Herman.I am looking now for the crankshaft.Hope someone has it in his carage ....![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I checked with Mark and he dose not have....
Archive Gatekeeper
What's your intended use for these GTS parts? If you want GTS pistons and crank it sounds like your constraints include using a stock block with 100 mm bores.
If you can't find a good GTS crank and R2 rods, Greg Brown has GTS-stroke cranks available that have improved oil delivery to the rod journals, and matching Carrillo rods that (I assume) could be made to work with GTS pistons.
https://rennlist.com/forums/928-foru...ankshafts.html
My guess is that the crank and rods from Greg would be about $5500 or so. Not sure what a set of R2 factory rods would cost (they were $170 x 8 when I last checked in 2010, so that's $1360), , and not sure what the market for a GTS crank is like these days but I wouldn't sell one for less than $2K. And the crank and rods from Greg would be a much better option, depending on your intended use.
To FBIII
I am using the original rods.i want to build the engine as original.with no modification.i know some engine run like 250000 miles till first overhaul. Actually my engine fail after 50000 km.i don't know why? I know the failure is failure of crankshaft thrust bearings .the car was parking for more than 15 years and I bought it from previous owner with this problem.
any way. I am building this engine again and survive this beauty.
You had the trust bearing fail, any damage to the engine block?
Trust bearing failure happens on the automatic 928, mostly to later cars 87-95.
http://jenniskens.livedsl.nl/Technic...ingFailure.htm
https://rennlist.com/forums/928-foru...pictorial.html
The pressure on the flex plate will have to be released every few thousand miles. Some are using an aftermarket clamp to stop the shaft from pushing against the crank.
Also, what year is the car. In 94 they changed the rods from 1R to 2R. So if you have 1R rods you may want to consider replacing them with 2R rods since the engine is already apart.
Edit: better link
https://rennlist.com/forums/928-foru...-gts-rods.html
Edit: better link
Basic Site Sponsor
Basic Site Sponsor
To FBIII
Inspect the upper block very carefully. There are usually cracks in the very brittle Alusil material that migrate out through the water jackets. Even if the cracks are very small, they will continue to crack, after you re-assemble the engine and it will fail almost immediately. The Alusil alloy is incredibly brittle.
If, by some incredibly rare miracle, there are not cracks, you will need to clean the sealant off of the block and the cradle and torque the cradle onto the block to carefully measure the bore of the center thrust bearing. It's virtually impossible to have the center thrust bearing fail and still have a "round" hole for the new bearings. I've never seen one that doesn't need to be align bored with even minimal crankshaft damage.
If this engine has the 1R connecting rods, they are junk and need to be replaced with the 2R version.
This thrust bearing failure is a real "bag of snakes".
Good luck!
greg brown
![](https://rennlist.com/forums/signaturepics/sigpic31574_1.gif)
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
50,000 km is about 31,000 miles. If this car is an automatic GTS, pretty low miles for a trust bearing failure. I thought failure usually happened around 70,000 to 100,000 miles. Unless at the factory some of the cars didn't get proper torque on the flex plate clamp bolt?
To FBIII
I think you need to re-visit the cautionary posts we made when you first introduced yourself and your 928.
The 928 motor rarely survives thurst bearing failure and until you have dismantled the motor it will not be apparent just how far reaching the damage is. As Greg has already articulated, when the thrust bearing fails it invariably spins in the crankcase and leaves hairline cracks and when that happens the block is to all intents and purposes history. You may be lucky but the fact that you seem to understand thrust bearing failure has occurred sad to say tells its own story.
Before committing to buying "bags of bits" you will do well to have the motor completely disassembled and analysed by someone who knows what they are looking at. Hopefully our fellow listers will be empathic.
Building a GTS motor piece by piece is not a cheap alternative. Your cylinder heads/cams are probably the only recoverable item and even then the tappets are probably toast because of entrapped metal and the oil ways will need a competent flush.
Sad to read this but you really need to advise the list exactly what you know before jumping to the next step as it were otherwise we cannot advise you appropriately.
I sincerely hope your problem is overstated.
Regards
Fred
