Ham fisted another one.
Ugh.
I was quick changing my fuel dampers and I managed bending the neck of the hard fuel line coming into the front of the forward damper.
It bent slightly, and even bending it back I'm concerned about fatigue. I will replace it rather then worry about it, but maybe somebody can benefit from my mistake down the road.
I had the rail off already and there isn't a lot to stabilize that damper as you wrench.
In short: I suck.
I would take the bracket off the water bridge and just do this all on your bench.
![Name: IMG_1023 (598x800).jpg
Size: 268.1 KB](https://rennlist.com/forums/attachments/928-forum/883166d1414943226-ham-fisted-another-one-img_1023-598x800-.jpg)
![Name: IMG_1024 (598x800).jpg
Size: 285.8 KB](https://rennlist.com/forums/attachments/928-forum/883167d1414943226-ham-fisted-another-one-img_1024-598x800-.jpg)
In short: I suck.
![Name: IMG_1029 (598x800).jpg
Size: 251.4 KB](https://rennlist.com/forums/attachments/928-forum/883168d1414943226-ham-fisted-another-one-img_1029-598x800-.jpg)
Team Owner
FWIW you can usually counterhold the dampers and B nuts,
then squeeze the wrenches together,
I like to put a lil dab of antiseize on the back of the bulbs and the threads of the connections so the B nuts will not seize
Yea, it's like that one bad pitch you make, that you wish you could take back...
Just makes me mad. Anyway, the project continues.
I will do that Stan, it was seized pretty good, every thing I could do to get it off, even when it was on the bench.
![Name: IMG_1032 (598x800).jpg
Size: 309.3 KB](https://rennlist.com/forums/attachments/928-forum/883333d1414979231-ham-fisted-another-one-img_1032-598x800-.jpg)
Been there. Screwed up the line on the fuel filter a long time ago from being ham fisted. Learned the art of counter holding and squeezing the wrenches together. Mopar never did it that way. Haha.
