928 Forum 1978-1995
Sponsored by: 928 Specialists
Ritech Flex Plate Clamp - The New & Complete answer to TBF
Old 10-15-2014, 09:38 PM
ROG100
Basic Sponsor
ROG100's Avatar
Default Ritech Flex Plate Clamp - The New & Complete answer to TBF
928sRus is please to announce that we will be taking orders for the new Flex Plate Clamp designed and made by Ritech Systems in the UK.
Richard Armstrong, the driving force behind Ritech Systems, is also an ardent 928 owner and prominent member of the 928 community in the UK & Europe.
Richard has been working for nearly two years designing and developing a new clamp to end the misery of TBF that is both cost effective and can be fitted without removing the torque tube and gearbox.
The Ritech Systems clamp locates behind the splined section of the driveshaft and around the existing clamp to provide positive location of the clamp on the shaft, so that the shaft simply cannot pull out of the clamp.
Any distance between the inside of the new clamp and the existing clamp is taken up by locking screws (not shown). The clamp is in two halves and extremely easy to fit.
Prices will be circa $250 - still looking at shipping costs
First 10 will land soon in the State of TX.
http://www.ritech-systems.com/928_flexplate_clamp.html
Old 10-15-2014, 09:42 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Pros/Cons to the Superclamp?
Im guessing..you dont have to pull the motor to install this one..right?
Old 10-15-2014, 09:48 PM
ROG100
Basic Sponsor
ROG100's Avatar
Correct!
Old 10-15-2014, 09:53 PM
ROG100
Basic Sponsor
ROG100's Avatar
A better picture
Old 10-15-2014, 10:07 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,183 Likes on 1,233 Posts
That is very clever, nice work.
Old 10-15-2014, 10:39 PM
Black Sea RD
Former Vendor
Black Sea RD's Avatar
In the picture showing half the clamp placed onto the drive shaft and OE clamp, it seems there is a very specific cutout to allow for the OE clamp and the rear of the drive shaft as it sticks out of the rear of the OE clamp. The cutout seems to limit the rearward travel of the drive shaft by the interference of the spline bump at the rear of the spline.
We have noticed that the amount of splines showing at the rear of the OE clamp varies when setting the float of the flywheel/crank off the engine's thrust bearing.
How would this new clamp allow for this variance of spline length at the rear of the OE clamp?
Old 10-16-2014, 08:46 AM
Dave928S
Dave928S's Avatar
Originally Posted by Constantine
We have noticed that the amount of splines showing at the rear of the OE clamp varies when setting the float of the flywheel/crank off the engine's thrust bearing ....
What do you attribute that to? Permanently bowed flex plate or rear coupler not lined up exactly could be reasons .. wouldn't it be better to rectify those issues before fitting any front clamp?
Old 10-16-2014, 10:35 AM
oaros
oaros's Avatar
Badly installed rear clamp, at least in my case; shaft moved until the cut-out rubbed against the clamp bolt.
ROG100
Basic Sponsor
ROG100's Avatar
It is important to release the rear flex plate and replace the bolt.
Old 10-16-2014, 01:22 PM
hacker-pschorr
These "Rogerboxes" are too complicated.... I'm going back to the much simpler double disc clutch
Old 10-16-2014, 01:47 PM
Ducman82
Ducman82's Avatar
^^^ ya TBF seems like such a hassle .....
Nice looking product though!
Old 10-16-2014, 02:03 PM
GregBBRD
Former Sponsor
GregBBRD's Avatar
Received 2,474 Likes on 1,468 Posts
Looks like another viable alternative, for clamping.
If anyone has been following my theory, on Hacker's thread about his new car....I believe any clamp is a "patch" and the age/deterioration of the driveshaft is the real issue.
I've never seen a low mileage vehicle (below 40,000 miles) have any flexplate preload. Yet, by the time they have 80,000 miles on them, the flexplate is buried into the flywheel. If this doesn't get caught, there's a good change that the engine will be trash by 100,000 miles.
The "progressiveness" of the problem points to a deterioration of the actual shafts, in my thinking.
We are testing to see if this theory has merit.
Old 10-16-2014, 02:18 PM
DKWalser
DKWalser's Avatar
Since my car is about to go past the 70,000 mile mark, I look forward to hearing the results from your tests! The pictures of failed shafts posted to the other thread were interesting and scary.
ROG100
Basic Sponsor
ROG100's Avatar
I agree Greg and look forward to your findings. Clamping on its own is not the complete answer.
The nice difference with the Ritech clamp is that it goes beyond just clamping and physically stops the movement - sort of like the original circlip did.
Fixing the root cause maybe the Holy Grail!
Old 10-16-2014, 02:19 PM
ROG100
Basic Sponsor
ROG100's Avatar
Thanks for the orders - as soon as I receive shipping details I will be in touch.
Quick Reply: Ritech Flex Plate Clamp - The New & Complete answer to TBF
