928 Engine for Sale (0 miles)
2nd Gear
M28, 2-valve, for '79-82, rebuilt long block, heads by Ollies of Santa Ana, never used (intended as spare for my 928). On stand in storage. No reasonable offer refused. Frank, fzanka@gmail.com
You might want to list what was done to it. Valve grind, I assume. Guides, I hope. New rods bearing? New main bearings? New rings? New Valves? New oil pump? Which seals were replaced? A photo on the invoice might be good.
Plugs are sitting at off angles. That is a little bit off-putting.
...Just suggestions....
A fully dressed all accessories 928 engine especially a 4 valve is pretty heavy for the average engine stand.....you get flex and sagging and need to fit a support brace under the front of the engine. They just do not feel right
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Hey Jim, so does that mean there is no problems fastening a 928 motor to the typical engine stand? I saw some heavy duty ones on Jegs capable of holding up to 1200 lbs. I assume that is more than enough for a fully dressed 928 motor?
correct they will work fine just do NOT try torqueing the front crank bolt while in the air
be very careful when moving it around and rotating the engine turning it upside down you will find how out of balance it is !!!
Former Vendor
The two upper bell housing bolts go into the "Alusil" (Reynolds 390) portion of the block. This material is very brittle, because of the added Silicon, and most people are not very "comfortable" with an "American Style" engine stand (what has four separate "post style" mounting flanges.) And when the lower "cradle" gets removed and only two of those posts are supporting the entire crankcase (with the crankshaft still installed) it gets even more exciting. The "Alusil" material has the potential to break off an entire section of the crankcase, which turns the entire crankcase into scrap metal.
![](http://i1033.photobucket.com/albums/a415/GregBBRD/DSCF2590_zps23b503b1.jpg)
By far, the best thing to do is to find one of the original 9127 engine support pieces (or hope that Hans finishes making these things, one day) and build a really heavy duty engine stand with the 313 head attached to accept the 9127 support.
The only problem....sometimes the correct way to do things is expensive.
I have a HD Princess Auto Stand (Canadian Version of Harbour Freight) and it holds a fully dressed S4 engine with no problem. Where it gets dicey is when you rotate the engine.
It is not whether the stand can withhold the weight, but whether you can withstand the off balanced nature of the motor on the stand. There is a lot of momentum when rotating the motor. I have a bent 3/4" steel pipe to show how much weight and force the engine has went it "gets away from you".
This is where a stand with a crank on it to do a controlled rotation makes sense. I know that Hans was working on a prototype a couple of years ago which I would buy in a heart beat.
There was a fellow recently talking about making an adapter for these blocks and I got the impression the issue was bolt pattern rather than weight. I did notice the WSM recommends a brace so I'm looking around for ideas on welding up a plate for a HD stand I could bolt a brace to.
Regards,
Former Vendor
From about post 3 on, we really trashed the OP's thread. Sorry!
Maybe we should talk about engine stands somewhere else and let this tread go back to selling this guy's engine?
To the OP....I'd think for anyone to be interested, you are going to have to list details....a "valve job" is not a rebuild.
I just added a 2x4 support under the front of the motor. Of course you cannot spin it in that configuration, but I don't do that very much anyway.
Regards,
