Removing Receiver Drier Dessicant Beads From AC System?
(edited to discuss drier desiccant beads rather than material previously suspected as system sealant)
A recent apparent blockage in the expansion valve let to us using a capture machine and emptying the system prior to installing a new valve.
We discovered small 'beads' in the valve and upon further inspection, more small beads in the receiver/dryer (see pic below).
Plan at this point is to use compressed air to attempt to clear these little bastards out.
Any suggestions on how best to proceed?
FWIW - my thought is to break the system down and blow out as individual components (condensor, evap coils, hoses, compressor). I think that would give the most effect from the pressurized air.
You're looking at a total tear down and flush Randy. Sorry bud.
The dryer needs to be replaced anyway. As should the expansion.
Lines as well.
Then you clean out the condensor and evaporator. Or some have suggested a "flush".
Lines as well.
Well that's what we're trying to avoid.
Will try compressed air section-by-section and hope for the best.
Kinda strange the AC worked for years with these objects in there?
That's interesting - so not 'sealant' as we originally thought? These can escape out of the drier - how?
If that's the case, we may have them localized to the low pressure side of the system.
Team Owner
Randy make note of the fact that when using any type of flushing liquid ,
the connections and the lines should be separated then dried out with compressed air then new O rings fitted.
NOTE doing it the other way adding new o rings first then flushing will most probably result in the new o rings swelling and leaking from the flushing fluid
Good luck,
Dave
