POD R/R with light enhancement 86.5
Hey all, I got the itch to pull the proverbial pod this weekend.
Combination of gauge and light issues.
I purchased a "light enhancement kit" on ebay, how wise a purchase remains to be seen. Essentially a mirror kit, after removing old glaze with acetone.
Attachment 837118
Attachment 837119
I'm replacing bulbs first, I may do LED down the road based on results.
We were speculating on the extra switch covered with the factory tape in the guts of the pod. My buddy said Euro thing, which sounds credible, anybody got details?
Attachment 837123
Kit includes mylar tape, to apparently control any light loss on corners of prisms.
The shop dog lost interest pretty quickly, he's only interested in honest HP upgrades...
Attachment 837124
Attachment 837118
Attachment 837119
Attachment 837123
Attachment 837124
Same old story, most of the work is the cleaning.
Getting enough torque to free 27mm nut on steering wheel without busting anything was the only trick.
Cheers.
Dwayne's write-up is the gold standard in tutorials.
One tip is to tape the rubber grommets to the pod - make re-installation much easier!
Anybody used one of these?
I have a aluminum shift gate and some other brushed metal in the interior. So I thought I would give this a shot.
I'm hoping for more light, it does make the gauges stand out, IMO.
Attachment 837301
Attachment 837301
As someone said, Dwayne's writeup makes pod removal a 2 or 3, the hardest part is being upside down under the dash.
The taped off switch is for the Euro rear fog light.
Attachment 837301
Attachment 837301
For pod removal, Shocki's 15-min removal thread is pretty good too.
https://rennlist.com/forums/928-foru...-ok-price.html
I like it, No Vector, looks good with the steering wheel too.
Hey, BTW, I would have to say putting this back together was more frustrating.
Not BLUE HOSE frustrating, but maybe 6-7/10 to line up grommets.
Attachment 837375
I also crumpled my intensive washer switch somehow, I may just put in a toggle switch instead of waiting for parts.
Attachment 837375
OK, thanks guys, pic's look great I have printed out Dwayne's and Shocki's procedures, confidence level is high so I will start the pod/ led light replacement next Saturday. I also purchased Ed Scherer's AILD 1 dimmer module and will be installing it as well.
Marine928
Marine928
Ok.
In and done.
Assessment: New bulbs and kit are brighter, but maybe by 30% - 40%.
Good enough to see gauges clearly, but I'm guessing LED would still be brighter.
Bonus: Got a functional voltmeter and gas gauge out of the deal!
In and done.
https://rennlist.com/forums/928-foru...el-lights.html
Read it till the end and see the youtube movie
Electron Wrangler
Alan
Dave looks fantastic!, NoVector, your's also looks great!
Dave, i have found the only difficult task re-installing is the passenger side
hardware with L shaped cast alum spacer.
I hold this assembly together with a small soft rubber O ring placed over the upper bolt threads which crushes when you tighten this bolt. Makes it easy.
I wish i knew i would have sent you pics.
Glad to hear the gauges are functional and hopefully it will be in a while.
Matt
Matt
Yes!
That's exactly what slowed me down Matt.
I had to line up the L shaped piece by working through the hazard switch hole with a pair of forceps.
All gauges operational, except oil pressure... stays pegged at all times except when running warm and clutch pedal down -- then I get great numbers.
I have assumed extra resistance somewhere, but I have replaced sender and R/R gauge as above.
RS looks awesome BTW.
I also took the time to make a dash and pod cover with black vinyl.
Attachment 837936
Attachment 837937
Attachment 837936
Attachment 837937
