Question while doing timing belt and trying to keep crank from rotating
#106
Inventor
Again with the P-A behaviour.
The second fastener issue was with the bolt supplied with the tensioner pulley from the manufacturer.
PKTs now come with a stronger, through bolt and nut for both pulley and lever and previous versions can be easily upgraded.
#107
Basic Site Sponsor
Basic Site Sponsor
No. The 1/4" plate only uses the 1/8" plate for spacing. Bolts loosened/were loose, first.
This is the same thing I've been saying for about 6 pages, on this thread......and has caused me to completely give up on you about your stuff.....there's something in your personality that just won't allow you to listen.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#108
I have to ask about this vibration issue you have been speaking of. As one of the failures was on an engine that I was the caretaker, I can assure it it was not having any vibration issues at any time that the PKT was on it. Are you referring to the track car that broke or is there a 3rd one we don't know about?
#109
Inventor
It would seem obvious, perhaps only to me, that if you would have listened to people who saw the original hardware was unusable crap, you would have been able to avoid at least one engine from failing....and a troublesome recall.
No one said the original hardware was suspect. The original design had a through bolt and nut, like the PKT-B now has, but it was decided to use the hardware included with the lever and pulley for customer convenience.
"There you go again." Stop with the listening already. You have made it abundantly clear that you, Jim B &C, et al, are not impartial speakers on behalf of any of my products, further, that any of yous have anything new to say.
If there were no previous damage to the bolt threads, then the cleaniless of the bolt, hole, and bracket on the 2nd belt install might be a factor.
#110
Inventor
I wanted to write an informative post to summarize factory cam settings versus advance/retard, but all this piling on has chewed up the time allotted. At any rate, I have talked about cam settings ad nauseum in many threads before, including one long one with Kibort.
Mainly, Greg needs to before using the PK32v'r (or PKT).
I do have to get some major things done during the next week or two, starting this weekend, so I will be signing off this (rather pointless) thread now, permanently.
Aloha!
Aloha!
#111
Actually, the reason for my measured comment was that the details regarding that particular failure came from you and Roger. I did not feel that it was my story to tell, but it is an important story I think. So shut up already with the P/A crap.
And by "issue" we mean a shear fracture of the M8 machine screw that attached the tension pulley to the bracket, correct? We need to think a little about what that means-- the static load on that tension pulley is only 100 pounds or so.
#112
Basic Site Sponsor
Basic Site Sponsor
Aloha!
Aloha!
And there's a major misprint in the PKT:
I can't find where it says to throw the whole fricking thing into the trash can and use the stock tensioner.
#113
Aloha!
Aloha!
