Something melted
Something melted
Somebody please tell me what this is, is it important and how much is it going to set me back this time
Close Up
And whole picture
Close Up
And whole picture
No, the connector just crumbled, and somebody used RTV to hold the pins in place. This happens with the knock sensors and the crank position sensors. I think that is the front most knock sensor.
Archive Gatekeeper
First thing to do would be to hook up to a diagnostic tool to see whether the front knock sensor is functional. If it's dead, you can pull the water crossover and the oil filler neck without disturbing the rest of the intake, and get enough clearance that you can get proper torque on a new front knock sensor.
Probably not a bad idea.... is this what you had in mind?
http://members.rennlist.com/pirtle/svc_intake.html
Archive Gatekeeper
Both knock sensors are identical.
I dunno about an intake service- I mean, you can certainly do one if you know you have a problem, e.g.- an air leak, dead/sticky ISV, non-functional TPS, etc, but in those posted pics the intake looks nice, everything is otherwise clean and dry, and the front fuel line has been replaced. Not sure I'd mess with the entire intake just to replace the front knock sensor, unless you want to, or have a definite need.
The Pirtle writeup is a good one, and so is Dwayne's:
http://dwaynesgarage.norcal928.org/1...%20Refresh.htm
Archive Gatekeeper
Should be doable- 'just' have to remove the MAF and the rubber MAF elbow. There are probably some 928 Ninjas with small hands that could do it with the MAF elbow on, but you want to be pretty close to 15 ft-lbs on the knock sensor bolts, piezo sensors need to be torqued down just so.... So you'll want some space to swing your torque wrench in there, to 20 Nm/14.7 ft-lbs.
Dont do either until you get the car running as it should be. If that knock sensor connector is in that shape both of them are toast under the intake. Which means you need to do a top end refresh.
Hence the "dreaming" part... When you say top end refresh, is that different than intake service.... Somehow I knew it wouldn't be 160.00 and a case of beer, seems more like two cases.
It all depends on how deep you want to go. If you don't paint/powder coat and replace every gasket/hose/seal/sensor you are looking at a grand just in parts. It goes up depending on how pretty you want it.
I will say that you should do it right the first time but I can advise that all day long. I had to pull mine 3 times before I got smart.
