Alternator duct - why it's needed?
This is a tangetially related post to the one asking about duct replacement. I was replacing my alternator a few weeks ago, and reinstalled the duct because everyone says to.
This may be a dumb question and I am probably overlooking something obvious, but...
the alternator seems to incorporate a fan with the pulley on the front side that forces air front to back. There is no extra fan in the duct that sucks air through or contributes to pulling air through the alternator. So if anything it seems like the best airflow through the alternator would be one with no duct (i.e. flow restriction - analogous to an open header vs. a very long exhaust pipe) or at the very least I can't envision how the duct contributes to cooling.
Maybe (this is a stretch) since the duct exits in the wheel well (cooler area) and hot air rises there is a "passive fan" created in the duct that aids in moving the air just based on the air temperature differential within the duct (sort of like a chimney)???
I CAN see value in the duct protecting the internals by helping to prevent water and debris from getting into the back of the alternator and I'm thinking maybe that is really it's purpose.
Basic Sponsor
Chris I always thought the fan sucked air through the alternator back to front.
Therefore also sucking ambient air passed the external temperature sensor.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Rennlist Site Sponsor
The fan is a centrifugal type. Spinning throws the air outwards from the fins, creating a low pressure area in the center, pulling air from the back to the front.
With no duct, you are pulling air that was heated by passing thru the radiator, then heated more by the exhaust manifold. Add a little oil vapor from the power steering leaks, and the alternator has a hard life.
In addition, as Roger says, the air flow ensures that the HVAC external air temp sensor gets a true ambient reading.
The duct is a good thing...
its purpose is to suck rocks and pebbles into the alternator, so they can bounce around in the alternator and break armature wires, so you need a new alternator. ask me how i know... ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
dont forget to put a filter over that inlet to the alternator.... i use a lady's nylon sock
It sounds like you are advocating putting a sock over the the inlet that you never had a hose on ?? ... if that is the case (no duct) then it wouldn't be surprising to me if you'd picked up debris .. and water ... and very hot air .. all of which will stuff up an alternator.
To the OP ... As Wally noted, the duct is a good thing. Look at the position, in close proximity to the road surface, and you can see why that duct is vital ... if you value your alternator.
Received 1,678 Likes
The only alternators I have had to replace were mounted without the duct. (Not saying that they won't fail with the duct; but my data shows that not having the duct is a bad thing.)
