What is the latest on differential oil
Not a very exiting topic, but I need to know anyhow.
I have the choice between mineral hypoidoil SAE 85W90 (GL5) and synthetic oil SAE 75W90 (GL5). Should I go with the (I assume old school) mineral oil or go for the synthetic oil?
I have an open diff.
Just replaced mine with Redline 75W 90 NS GL5. I did a bunch of forum searches beforehand. Some people like Royal Purple, some like Mobil, but concensus seems to be Redline 75W90 NS. No LSD makes it easy. Some LSDs complain that they get chatter unless they add a little friction modifier. But too much friction modifier is not good for smooth shifting synchros. Although mine seems fine without it.
Former Vendor
I'm a fan of Mobil 1 75/90LS. Does everything that I think it should do, for "normal" everyday usage. Works well with the limited slip. It is syncro "friendly". It does a great job of protecting the gears and the bearings. And, it doesn't leak past the seals.
I'm not a person in a constant search for something better. Once I find something that works, I stick with it, unless I have some sort of a problem with that product. Therefore, I have not tried every single one of the transmission oils out there.
However, I do rebuild and have rebuilt a lot of transmissions, over the years. Redline leaks past the seals on a fresh transmission, to the point where I insist that if people want me to warranty the transmission from leaking, they can't use that gear oil.
Thanks for sharing your experiences. Since the mentioned Mobil 1 and Redline oils synthetics I will go with the synthetic equivalent the more readily available LiquiMoly. I use LiquiMoly TopTech 1100 ATF for the gearbox and am happy with it.
Former Vendor
I do not.
By some sort of "RPN" logic, I figure that if regular Dexron II won't work in a vehicle that was made for Dexron VI, the reverse might not be the very best of ideas, either.
I use a special high performance fluid that survives in my 2 speed Powerglide (with transmission brake and 3,500 rpm stall) and 570 cubic inches of BBC (in my 63 Nova.)
I figure that if it survives there, one of my stroker 928 engines isn't going to stress it.
Former Vendor
Yes, definitely not an issue. It has a friction modifier for the limited slips, which is not a negative thing for open differentials.
Hmmm... I just looked back and see that I used Castrol Syntec 75W-90 (GL-5) on my last change (quite a while back) on my '90 S4 (PSD). I can't remember exactly why I picked that one. Looks like maybe that's been replaced by "Syntrax™ Limited Slip 75W-90" (same thing, different name, maybe?).
Any comments on that choice?
(Edit: Based on a post on another forum, "Syntec 75W-90" was renamed to "Syntrax Limited Slip 75W-90" in November, 2011.)
Flavour of the day....
Flavour of the day.
Doing the flush again this spring, so I'm reading this thread with some interest.....
