Running cold: good- running warm: BAD
I am at my wits end on this one -
From a cold start and minor warm up to get oil circulating, it runs perfect. The more I drive it and the warmer it becomes (not hot)
it begins to run like crap. It will pop back, run only on 7 cyl.
This is what I have done:
1) new plugs
2) new wire set
3) clean injectors
4) cleaned the 14 plug connector
5) cleaned the connection to the coil
6) can of Techron
I just ordered a new green wire from Roger.
Could it be fuel pressure?
1) new plugs
2) new wire set
3) clean injectors
6) can of Techron
I have checked the vacuum lines numerous times, no gas smell
I did have the intake off recently when I had all the injectors cleaned. The heater is intermittent. ( some times it works sometimes it doesn't )
Team Owner
Install the green wire
Intermittent heater - air bubble in the coolant ? Assuming its K-jet ----I had a misfire in mine once, and I was able to isolate it to a specific cylinder. The problem went away after I cracked open the injector line to that cylinder. My local wrench who does a lot of work on K-jet 911s guessed that it might be a piece of crud in the distributor head blocking that injector outlet. After about the third such event, it never came back.
jp 83 Euro S AT 55k
jp 83 Euro S AT 55k
Since its an L jet......(if the green wire doesn't fix it) try this...take resistance readings of the temp II....if that is in normal range than pull the L jet plug in passenger footwell and take resistance readings for the temp I sender which is inside the AFM..... If it is even slightly off, it can do this....my lemons racer had this problem....a new (used) AFM fixed it right up
I just put in a new green wire and this seemed to help a bit but didn't correct the problem. I think Brian is on to something but getting the readings of the temp II is a bit over my head. Is there a thread that can walk me through it?
Don't overlook a MAF out of calibration.
My S4 what you have described. After 3/4 hour of highway driving a loss of power and lean popping.
Swapped in a good MAF and problem gone.
