32V hot cams on eBay
#46
Jim nailed it very well, thanks. Different applications needs different cams![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Wouldn't all of the elgin cams does have 114LSA?
65-6 Cam specs:
IN .414 lift 260 deg. duration @ .006 lash, 217 deg duration @ .050 lash
EX .370 lift 246 deg duration @ .006 lash, 208 deg. duration @ .050 lash
LSA 114, Int LCA 120,5, Ex LCA 107,5
This gives me something like 25 degrees of overlap, which supposed to be "just fine" for street/race application(something like 20 - 30 degrees).
Need to model different grinds to understand more about cam timing events to make them match to my heads. Now having stage II from Colin.
One of the most important thing to fill the intake ports with epoxy was to get back the torque, which the Porsche engineers lost with uber large volume ports in 32V engines.
To get higher smooth torque curve together with good power(perhaps only 450ehp or little more) the cams needs to match with rest of the engine setup.
Exiting project from my point of view, even it's not any all out high hp engine
65-6 Cam specs:
#47
Been on my mind for a long time, but without the means to experiment.
Interested to see your results.
#48
The answer is right there with in the 968 cam specifications.
For emissions and idle, you want high LSA and low overlap.
For mid range torque, you want low LSA and high overlap.
For high rpm, you want again high LSA and low overlap, if you have to keep the cam lobe profile constant. But that's misleading. You want to have low LSA and high overlap, but you really, really want to have a late IVC which is more important than LSA and overlap at high rpms.
Graph from Greg Gray:
![Name: Cam968.jpg
Size: 138.9 KB](https://rennlist.com/forums/attachments/928-forum/797164d1389790261-32v-hot-cams-on-ebay-cam968.jpg)
#49
Terry, for some strange reason your post has seized my eyeballs and won't let them go.
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Can you elaborate a little more on your engine details?
Plllllleeeaaasseeeeeeeeeeeeee .....
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Upfixen.
'90 GT
#50
Jim , My car is the first 928 to run the tri flow cams ( staggered intake lobes ) looking at the dyno runs they all start at 2500 rpm and show 250-260 torque . I think the concept with the staggered opening of the intake valves was to maintain air flow at lower and mid range rpm , and create more of a swirl in the chambers .I have run 4 or 5 DE with it , 3000 rpm it pulls hard 3500 rpm and up it just a linear rush . Colin has posted some utube clips of the car idling ect . The motor is stock with cams and exhaust and tuning . 70k never had the heads off .
#51
The LSA for S4 cams is 106,5 degrees, for S3 114 dgs, for GT 110 dgs, for GTS 118,5 dgs, for Colin´s cams 114 dgs and for some street (sports) cams made in Europe 110 dgs, for racing cams 105-108 dgs. The extremely mild S4 stock camshaft do not have hardly any overlap at all, about 0,5mm (.002") of lift at TDC. Racing camshafts up to 5,5mm (.216") of lift at TDC for this kind of engines. Stock S4 cams perform best retarded, racing cams best advanced.
And yes Simos is right the intake port is too large for a 5 litre engine and the floor is too low for best flow.
Åke
#52
Since they are welded S4 cams, I would think the lobe-center would be the same, and would work well with a set of GT exhaust cams (as Greg pointed out above). LSA would be be just slightly larger than GT, 110.5 (splitting hairs).
That's assuming they are straight, and stay together of course
#53
Got to ask , where are you going to find a pair of GT exhaust cams ? regrinds ? The straight and hold together part is what worried me , with Threshie cams .
#56
This is the graph and numbers from Terry's 928.
You can see at 2900rpm it is over 290rw ft lbs, and stays over 310 rw ft lbs from 3000rpm to about 5600 rpm where it then drips down to 306 at the very end of the run.....
#59
in all seriousness, my 335 was all stock, with 85 cams..... no mods other than headers and RRFPR. remember, i cant tune mine with out changing out the ECU. also remember that i have a safe tune as we did hook up the shark tuner and saw some decent characteristics, but its not tuneable, or as easy to tune as other "stock" S4s.
anyway, 350 with a street set up is pretty awesome. I think if i got some big cams in the stroker it might be hitting that 400rwhp mark with the stock intake and ECU.
#60
