Save Your Money- Cam Timing Gears
Just received my re-coated cam timing gears back from Finish Line Coatings in Oregon. Given that it was $45 per gear for a dry film lubricant finish on the gears, it is a long stretch to get to the $400 per gear if you replace them.
I could not be happier! They look amazing! And they permanently marked my gears with distributor rotor placement and cam timing reference points.
The can of paint was about that with shipping, so its more economical to buy a small oven and do it at home.
Archive Gatekeeper
Maybe it's my imagination (or because you posted a beautiful high-res macro picture...) but I think I can see on 4-5 of the teeth where there is some mild cupping of the recoated teeth where the belt was riding (?). I'd certainly use those gears but I'd be interested to see if the coating holds up as well (or as evenly) as it would on a new set of gears. Not that I'd sandblast a new set of gears and get them coated, just for the sake of the experiment......
I've done a few things with Cerakote, an equivalent film coating. BC, the problem is most folks will buy the product, use it once and throw it away after 4 years on the shelf in their garage. But, I do agree, for the DIY guy it isn't that hard. You will need an airbrush with proper low pressure airflow and some practice.
any before pics?
btw.....there are alternate new gears available at much better cost; Roger has them
The new aftermarket cam gears that Roger sells are pretty well priced IMO, and you support alternative parts sources, which leads to other cheaper alternatives being offered, win win.
