So how do I torque them when on the ground? There is not enough space to get a wrench once the car is on the ground. The car cannot go on Ramos because it is too low and the spoiler will hit before the tire goes up.
Can you just put a jack under the wheel hub and then torque these?
Sorry for the hijack.
If there isn't room to get a long 19 mm socket on a 1/2" drive torque wrench on the rear LCA bolts with the car on the ground, your ride height is too low.
Be careful to check the torque settings carefully- as I remember there is quite a difference between the rear most bolts and the front ones- the front being somewhat lower. Do not fall into the trap of finding one setting and assuming the other is the same.
I have a new rebuilt lower front a arm. Do you install dry, or grease the the rear bushing?
Thank You
Mark
Yes, dry, as Stan said. I have installed a pair of Mark Anderson's rebuilt arms, and with the new rear rubber they do not go into the rear bracket easily. I had to use a jack under the arm to get it in enough to install and snug up the bolts. The rubber will compress, but the first time it takes some doing. Then you torque the rear on the ground, as other noted. The shop manual covers this. The front bracket bushing is fixed, bonded and does not move in the bracket (it merely twists elastically), so the front bracket can be torqued either up in the air or on the ground. If you ever find that the bonded front rubber bushing begins to rotate in the bracket, that means it is broken and the A-arm needs to be replaced.
