928 Forum 1978-1995
Sponsored by: 928 Specialists
I am about to push this freakin car off a cliff!!!
Old 10-29-2013, 12:06 PM
johnu
johnu's Avatar
Default I am about to push this freakin car off a cliff!!!
This TB/WP job has been ongoing for over a month now!
I have broken 4 wp bolts (all fixed with time serts now), and everything else has been a huge pain in the ***....
Now I have one frickin bolt left to take off before I can begin re-assembly....it is the 6mm hex at the driver's side rear of the waterbridge....the one that is barely accessible with an allen key. It is starting to strip due to all my efforts, and won't budge. I have soaked it with PB for two days now. I can't heat it due to fuel lines. I am NOT taking off the intake.
Any ideas? I am ready to give up!!!
John
Old 10-29-2013, 12:11 PM
TexasDude74
TexasDude74's Avatar
Go back in time to 1987 and apply PB Blaster to the bolt at the factory? Why else would you have a Delorean?
Old 10-29-2013, 12:15 PM
MainePorsche
MainePorsche's Avatar
I got my set of these at Sears. Saved my skin on a few jobs.
Old 10-29-2013, 12:19 PM
jeff spahn
jeff spahn's Avatar
Have you given it an attempt with a manual impact hammer? These can save many a stuck bolt. There is also an electric bolt heater that will only heat what it is applied to. Perhaps you can borrow one from someone?
no affiliation: http://www.theinductor.com/index.php?m=41
here's another:
Bolt BusterTM Magnetic Induction Heater Tool Coil Kit Included - Amazon.com Bolt BusterTM Magnetic Induction Heater Tool Coil Kit Included - Amazon.com
Old 10-29-2013, 12:42 PM
17prospective buyer
17prospective buyer's Avatar
I feel your pain man, i broke or stripped a couple of those water bridge bolts. If you strip it right out see if you can weld a nut to the head. Also i actually find Torx bits grip hex heads pretty well... not the right way, but they do work, just need to find one that's slightly larger than the hex, and hammer the damn thing right in there till you feel it bottom out. Might work... then again might the torx bit might snap off in the head (done it before, and it double f%$#'s you over). You also might want to consider breaking off the head of the bolt, as there are no threads in the water bridge itself, the bridge will come off, and the remaining part of the bolt you can weld a nut onto to take out or use vicegrips and some major strength to thread it out.
Old 10-29-2013, 12:45 PM
1989porsche928
1989porsche928's Avatar
You sea foam deep creep and apply hest to that area inbetween spraying it on. It will be easier to remove. You could always drill it out
Old 10-29-2013, 12:51 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Id take off the intake.
1/2 of your current problems are under there anyway.
And all of your future ones left untouched.
Its a 30min job...maybe 45min.
Old 10-29-2013, 12:53 PM
PHIL928
PHIL928's Avatar
Just drill the head off. Once the head is off the whole bolt will be loose and will turn out easily enough with just pliers. Done it a few times.
Old 10-29-2013, 12:59 PM
johnu
johnu's Avatar
although not helpful, that comment did make me laugh!
The bolt is very inaccessible so some of the suggestions wouldn't work. I'm thinking drilling the head of the bolt off would be good since there are no threads on the waterbridge itself
thanks all
John
Old 10-29-2013, 01:04 PM
davek9
davek9's Avatar
shoot... I was hoping to see a YouTube of car going off clift
Old 10-29-2013, 01:08 PM
johnu
johnu's Avatar
That still may happen!!!!
Old 10-29-2013, 01:10 PM
Gunmetal
Gunmetal's Avatar
I'm with Davek
Old 10-29-2013, 01:17 PM
Lizard928
Lizard928's Avatar
If you drill the head off the bolt you will be pulling the intake to lift the water bridge off.
If you do strip it, get a torx bit and hammer it into the bolt, then undo it.
Old 10-29-2013, 01:23 PM
Shane
Sharkaholic
Shane's Avatar
You can also cut the short length of the allen key off and using a hammer to tap it into the fastener, then use a socket or wrench on the straight section of your allen key to get more torque to the bolt.
Old 10-29-2013, 01:47 PM
17prospective buyer
If it's already even a little stripped, using a hex will just make it worse, hammer a Torx bit into it, Torx grab pretty good, i use them as an extractor for stripped hex bolts almost as much as i use them for actual torx heads!
Quick Reply: I am about to push this freakin car off a cliff!!!
