GTS tuning options
By the sounds of it he wants another 100 crank HP. This would be a low pressure turbo application (or mid pressure, depending on your definition) to which the 928 motor SHOULD hold up just fine. Head deck condition (no corrosion near the fire ring) should be a primary concern. Every head gasket failure I have seen on this board is due to that condition. Not saying that boosting didn't kill the head gasket, but it seems a little far fetched considering the quality of Porsche materials. I would be curious to see a failure mode on a head gasket that WASN'T related to the blowout under the fire ring caused by corrosion... anyone have pictures to help enlighten me?
im guessing another 100hp would put me back on the top spot, if i can use the extra power with the planned wheel/tyre mods.
anymore power would be good if reliable. just looking at all the options you are all suggesting!
i dont know the current hp. standard gts even the ecus, just a x pipe and equal length headers.
the budget should be be big once my old aircooled gt2 racer is sold. someone has nearly done a deal with us so fingers crossed. ive just got to buy a ring and pinion and ecu for my cayman racer then the 928 can get some $ spent on the old girl.
many thanks for all the replys and private messages
what a great place this is!
Former Sponsor
Under the Lift
s. After several ORR passes now made with the engine, from what I hear about the engine, it's now pretty much dead, needing another build (I have not been involved since the assembly).
Yes, in fact a couple of engines. Fitted with Jenvey ITBs and using JDS ALpha system.
No reliabilty issues with the engine. Using GB sourced cranks and rods, 944S2 pistons.
A stroker with a stock intake would get you there......then if you need more power later, add JDS Alpha with M5 ITBs.
Mark,
We made 438 rear wheel horsepower out of a 5.4 GTS engine. Using JDS Alfa-N and M5 ITBs. As far as I know, no one has made more bhp than us out of a standard size 928 engine using normal aspiration. Before we get into the argument, it was done on a Mustang Dyno - the most conservative of all conservative dynos.
Even when not running well due to cylinder galling, I was as fast as a 997TT on the staight at Brands. Should make even more bhp on the rebuild motor. The reason for the rebuild - JE Pistons are a bunch of lying barstewards, but that is a different topic all together... PM me if you need more details...
Btw, for all the others - Mark will not be allowed to Turbo or Supercharge his race car due to class rules...
George
90 S4 Grand Prix White (Murf #5)
94 GTS 5-Speed Midnight Blue
06 Cayenne S Havanna/Sand Beige (PASM)
http://928.jorj7.com
ill message you later alex thanks, gotta go to work now.
i would keep it 5.4 if i could get that sort of hp from bolt on parts like cams inlet etc. how i read the rules, i thought it just mentioned mulitplying the cc x 1.7 on forced induction cars to fit them into certain classes? i better take another look before i order x amount of parts i cant use!
thanks for the info as well john!
