need source 32 mm tie rod wrench
There has been much to-from and whether or not you need a "thin" 32 mm wrench. The deciding factor seems to be how new the car (928) is. Finally got around to jacking the can onto stands (because it is gravel needed to get wooden sheets). Finally got underneith and there was no way to budge the stop so I guess I need the "thin" 32 mm wrench Does anybody know an economical source? Even if I have to take the car to my local mechanic I don't want him to reinstall the tie rod with a pipe wrench!
harbor freight has a whole set of thin, metric wrenches for like $40... I used them for not only the steering rack but to replace the oil pressure sensor....
