Chebby V8 conversion on a 90GT?
#61
Shameful Thread Killer
#63
Here you go Doc, answer to all your problems. I am sure Greg Brown would approve of this.
http://www.ebay.com/itm/New-Ford-Str...ed63da&vxp=mtr
#65
Anyway, I've got some time in various 308s, and they are much more raw than the 928. No power steering, modest vac assist brakes, rattling doors, and maybe dash, very low polar moment of inertia. Point and shoot and it goes where you tell it. The mx on my Mondial hasn't been too bad. I've had the typical CIS issues that most deal with. Just replaced the fuel pump a few months ago, AC sketchy, slow window wind-up, various slight oil leaks that will never go away. Torn axle boots, lose front end bushings from high miles, and the typical rubber perish that happens to all 25YO cars.
The high point of the Mondial is the very low entry price, outstanding engine performance and great suspension and brakes. I wind it up with the top down and live to hear the snarl from the engine. It gets a lot of looks and although I can't outrun any modern sports car, it keeps up in the corners. My tires are too old to do much fun stuff, but I'll be getting new tires soon and I can wring it out better.
#66
I see another problem, probably the root of all your issues --- Doc, you have WAY too many toys. Maybe cars, planes and other motorized toys are like shirts - you can never have too many --- but it looks like you are stretching it a little too far. You need a crew to help keep all your things in running shape. Fortunately, I now have only the one car, with a few motorcycles for backup.
#67
It's all just a function of money. I could have paid a shop to put a new engine in the ski for $3400, but the machine was worth less than that to start with. I was thinking of getting a Navion this week, but things didn't work out. Prolly a good result.
#68
#71
Better than a Chevy - a Ford Cammer
This would work just fine + it's 200 lbs+- lighter
http://www.roushyatesparts.com/Road-Racing-s/622.htm
#73
#74
The only $25K Ford Cammer that belongs in a 928 is this one:
If it was my GT and I didn't have the time/inclination to fix it myself I'd have it at Sean's post-haste. Do it once, do it right.
#75
LS376/525hp Crate engine, engine controller kit, serpentine system, A/C compressor, alternator, power steering pump, water pump, starter, brackets & tensioners delivered to my door for just under $ 9,900.00. Comes with a 2 year warranty. This set up is approx 150 lbs less that what came out. No timing belt to deal with, modern, programmable engine mgmt system, etc, etc. Note that there are conversion kits out there for the GM SBC & LS's and not for any other mfr that I am aware of. T
http://www.superchevyperformance.com...525_Engine_p/1
