928 Forum 1978-1995
Sponsored by: 928 Specialists
Trans Rebuild Started
Old 10-17-2013 | 10:20 PM
  #31
Bertrand Daoust's Avatar
Bertrand Daoust
Originally Posted by NickT
Impressive work!!
Well done . . .
+1.
Old 10-17-2013 | 10:33 PM
  #32
MGW-Fla's Avatar
MGW-Fla
Truly its a work of 928 art Glen!
Old 10-17-2013 | 10:41 PM
  #33
Black Sea RD's Avatar
Black Sea RD
Former Vendor
Impressive work!
So does this mean the 928 owners now have an East Coast transmission rebuild solution?
Good luck with the rest of the work and thank you for posting your progress.
Old 10-17-2013 | 10:42 PM
  #34
MainePorsche's Avatar
MainePorsche
Great job Glen.
I had learned a lot about the transmission's components when I had my failure. I was not as brave as you to rebuild the unit. I took the easy way out of the dilemma.
Old 10-17-2013 | 11:05 PM
  #35
G8RB8's Avatar
G8RB8
It doesn't appear that you will need it, but there's thread with a lot of info in one place here.
Old 10-18-2013 | 10:22 AM
  #36
Glen McCartney's Avatar
Glen McCartney
Jim, thanks for the thread, I had seen it in the past, forgot it was out there. It is a great thread.
Old 10-18-2013 | 02:06 PM
  #37
85euro928's Avatar
85euro928
Glen,
I think you found your calling! Maybe you should open up a shop here on the East Coast, we could use some transmission talent out this way
Old 10-18-2013 | 02:39 PM
  #38
Tony's Avatar
Tony
I want to be a fly on the pod when you start it and put it in "D" and drive off.
That will be a "nail biter!
Hope it all works out for you, it looks great!
Old 10-18-2013 | 04:55 PM
  #39
atb's Avatar
atb
Glen,
Can you share where you sourced your hard parts from?
Old 10-18-2013 | 05:04 PM
  #40
Glen McCartney
Adam, got gasket set with frictions and metals from Transtar. I probably shouldn't have bothered with the metals as they really weren't needed. I only used two of the 8 pieces I received and the rest did't match the thickness needed. Got the B2 band, valve and support from Roger, Greg said they should be changed at the same time. Got the thicker circ clip for the K2 clutch as the measurement for the clearance was too large, I used the 3mm to get it in spec, through local MB dealer
Old 10-18-2013 | 05:07 PM
  #41
Glen McCartney
Thom, don't know if I ever want to do this again. Before everyone starts looking to me as the east coast transmission guru, lets see if it works when I'm done!
Old 10-18-2013 | 07:33 PM
  #42
85euro928's Avatar
85euro928
Sorry, I'm just trying to throw a little business your way
Old 10-18-2013 | 10:16 PM
  #43
Glen McCartney
Thom, appreciate that. I'll hang out my shingle as a 928 transmission specialist when I confirm that this works. Plus, need a garage with a real lift, not just a scissor lift, a real transmission jack....Not much fun laying on a creeper.
Old 10-18-2013 | 10:48 PM
  #44
MainePorsche
Yes.
I replaced my transmission while on liftbars. Most of the time I wasn't on the creeper.
  #45
Tony's Avatar
Tony
I'll be doing mine on jackstands. Lifts are for pu$$ies!!
Quick Reply: Trans Rebuild Started
