928 Forum 1978-1995
Sponsored by: 928 Specialists
GTS Engine Cut Out - Intermittent
Old 11-12-2013, 02:47 PM
  #31
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,537 Likes on 1,427 Posts
also get your IR gun and shoot the relays after a while of operation any that are hotter than the rest have bad connections and should be investigated
Old 11-12-2013, 04:20 PM
  #32
PHIL928
PHIL928's Avatar
Had a similar deal with Gisherton's GTS turned out to be a crumbled connector at the CPS. It get's pretty hot in there, it really takes its toll on those connectors.
Old 11-12-2013, 04:28 PM
  #33
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,772 Likes on 1,346 Posts
Randy-
FWIW, the clamp on your MAF elbow/lower MAF body connection is clocked a bit strangely, normally they're clocked so the bolt is pointing towards 9 o'clock (as viewed from the front of the car) and you can get at it from the passenger side. Yours was clocked at about 4:30 or so, so that it could be turned from above with a long screwdriver between legs 7 and 8 on the intake manifold. Bill and I commented about it at the time, IIRC he left it in that orientation.
Old 11-12-2013, 04:50 PM
  #34
Randy V
Randy V's Avatar
Good idea! should have done that before I swapped out the first one.
Originally Posted by Rob Edwards
Randy-
Yeah, exactly my problem. I tried a loooong screwdriver between the manifold legs but couldn't get the correct approach to get it straight on to the bolt head. Looks like I'll have to try it again if you guys were able to get it.
Then reclock it to the correct orientation upon reinstallation!
Old 11-12-2013, 05:29 PM
  #35
Bill Ball
Under the Lift
Bill Ball's Avatar
Randy-
Yes, it was actually pretty conveniently located, accessible from the driver side, as Rob notes. Usually the clamp is accessed from the passenger side and requires removal of the fuel rail cover to get a shot at it from under the fuel rail. Always a pain. In your case, once I spotted it, it was very easy to get to. One thing that can happen after you loosen it, is that when you go to tighten it, the clamp will slip and the screw head will disappear from view. So, I try to get something on the clamp band so it does not move when I tighten it, and I only loosen it just enough that I can get the MAF out, leaving it a bit snug on the boot, which also prevents it from slipping and disappearing. I think yours moved a little downward when I was tightening it, but I managed to get it snug with the screwdriver. It may now be at a little bit of an more obtuse angle, but should still be accessible and you can re-position it up a little after you get the MAF off.
So, the CPS connector is on the front of throttle cable bracket under the MAF and fuel crossover pipes.
Old 11-12-2013, 08:13 PM
  #36
Tony
Tony's Avatar
ya know..i never thought of that. Good idea.
Old 11-12-2013, 08:52 PM
  #37
Bill51sdr
Fleet of Foot
Bill51sdr's Avatar
Originally Posted by Randy V
I've decided to approach this methodically starting with relays (after replacing the ignition switch last weekend). I wanted to take a look at the ground points but was unsuccessful in getting the MAF out. Should have paid attention to Bill Ball when he swapped my MAFs at SF this year. I couldn't get a wobble drive socket onto the clamp bolt.
I pulled the Ignition Relay XII and replaced it with another good -53 relay. This relay looks suspect as one side of the cover is smooshed in from some previous unknown side force.
Did not experience any cut-out during the drive this morning.
Randy,
Had your exact symptoms on my '86.5 and it was the LH relay.
Really surprised Jim Bailey hasn't been in here yet preaching "relay, relay relay... "
Old 11-26-2013, 06:28 PM
  #38
Randy V
Randy V's Avatar
Had replaced the Ignition relay and the problem seemed to go away - until yesterday when I needed a tow home.
Will try the LH relay now.
Any thoughts on fuel pump failing?
The engine runs normally then will completely die. I can continue coasting at freeway speed, put it in neutral and the engine starts and runs again for a few minutes, then it dies again.
Old 11-26-2013, 06:52 PM
  #39
the flyin' scotsman
the flyin' scotsman's Avatar
Randy.........my fuel pump failed on the s4 while on the highway and it was as if the ignition had been switched off. Car was towed home where of course it started as if nothing was ever wrong. As I had previously replaced all the 53 relays and much other work I deducd eith er the FP or LH but wasnt getting the relay chatter so a new pump, 'S' pipe and filter and she was as good as new.
the GTS will also have the intank filter which should be changed or converted so theres no future concern.
Old 11-26-2013, 10:12 PM
  #40
Randy V
Randy V's Avatar
It's looking like the fuel pump based on various tests performed so far.
Old 11-26-2013, 10:40 PM
  #41
Randy V
Randy V's Avatar
Spoke too soon - no loss of fuel pressure when the engine dies - so not the fuel pump.
Old 11-26-2013, 11:23 PM
  #42
Mrmerlin
Team Owner
Mrmerlin's Avatar
use the IR gun check the relays check the battery connections and the grounds at the rear of the V
Old 11-27-2013, 12:29 AM
  #43
the flyin' scotsman
how do you know that? didn't you remove the FP guage?
When the S4 pump failed it would start repeatedly but I never trusted it again until I swapped the pump out. Should also explain when it failed on the hwy it was after hitting a small bump on the road at speed; +160km/hr
I wouldn't waste time with the relays other than to replace all of them (the 53s) with new.
Good luck.
Old 11-27-2013, 12:33 PM
  #44
Randy V
Randy V's Avatar
Done, done and done.
Installed a temporary gauge on the fuel rail.
Old 12-02-2013, 01:14 PM
  #45
Randy V
Randy V's Avatar
Still no luck.
Looking at the ECU for possible cracks in the circuit board traces or bad solder joints.
My mechanic calls it a DME (Digital Motor Electronics) - he insists that is the correct terminology.
Quick Reply: GTS Engine Cut Out - Intermittent
