Idle micro switch ?
From: Wrong Island NY, 04 CTT , 1984 S 5 Speed Slate Blue Metallic
Just noticed that the idle micro switch on the 84 was loose and not being activated with throttle closed, I have adjusted it. I got rushed out by the Wife before I could test drive but could this be a reason why the RPM's drop so quickly between shifts ?
fsharp9. The idle switch is I think supposed to lower injector pulse width with throttle closed. think it helps prevent backfiring from to much fuel to air ratio. I think that's called overrun. Maybe the PO did loosen the mounting for some reason. Test the switch operation w/ multi meter. should be open ckt when operated and closed ckt when not operated. f#9 makes me think you're a music man?? I forgot to ask if it was the upper or lower switch?
Lower switch , screws were loose , according to the meter the switch is fine,and yes , I have been a professional touring /session guitar player ( Gun for hire ) since '89 ......Big hair and Marshall days
Hugo
I used a long screwdriver and removed the drivers intake tube
After an hour or two of cleaning/treating the seats with Lexol, I took a quick look at the microswitch setup again. I might have been able to get a super-stubby screwdriver in there when I was 5 years old, but not now. Looks like I'll need to remove at least one intake tube and even then, it's looking "interesting".
Hugo
Hugo
When the idle switch is closed (off-throttle) and the engine RPM is above ~1200 IIRC, the L-Jet shuts off the injectors to save fuel, that way when you coast down a hill in gear you aren't burning any gas and you get an engine braking effect. Once engine RPM falls below ~1200 RPM the L-Jet fires up the injectors so the engine doesn't stall.
FSharp9, I didn't notice any change in behavior in RPM drop betweem shifts, so I would say your issue is probably unrelated.
Hugo
