In need of 3 clips for middle door skin/card
Does anybody have 3 extra metal tabs that hold the middle section of the door skin/card in place that they can part with?
If so please let me know what you need for them.
Thanks in advance
Mj
Thanks in advance
Mj
The problem is. . . . .
So, what is it that you are inquiring about???
If it is the plastic clips that you need, I buy them by the hundreds for my projects and I'll send you a few. Let me know. If not, then????
Are you talking about the flat metal clips that hold the bottom of the leather insert on the inside of the door panel?
Basic Sponsor
The metal clips are 928 555 327 02 and we sell for $1.50 each.
The plastic clips on the pre 86 cars are special to the door card and the part number is 999 951 559 40 or you can use the more common white clip 433 867 299 A. Less than a $1 each.
Emailing you now.
Thx
Mj
What you need to do is break off the part of the plastic clip that protrudes leaving the head in the hole. Then use your needle nose pliers to fish the head out. They will turn sideways and then the notch can be used to fit them sideways throught the mounting hole.
I thought you just twist them out the same way as you would twist a new one in.
That's what I thought also, but it didn't work for me recently when I did both of the door panels in the 90 GT. I think the main problem was that they will not tilt over enough after they are put in to be able to have one point of the notched head start back up through the hole in order to twist the rest of it out.
