For those with pan spacers and mini starters: remove stock starter mount?
Holiday Inns are so choice. If you have the means, I highly recommend staying there.
Interestingly, in this spectacular thread, https://rennlist.com/forums/928-foru...pacer-kit.html, Carl was originally recommending only the one gasket, and JBWeld or Hondabond between the block and spacer. No explanation for the switch, but the instructions (and the kit, since it comes with two cork gaskets) call for using two. Who am I to ignore instructions...
The starter came from Carl; it's the IMI hi-torque mini starter that was often discussed here. Sadly, very little in the way of instructions provided.
Here's the pan spacer instructions; the sandwich is on p.3 (downloaded image is too large to attach)
ftp://928m:928m@66.188.116.26/instal...stallation.pdf
Could you post the second picture you sent me, with the relief cut out in the pan to facilitate the small head allen bolt for the top starter bolt? I think I'd have to take even more material out than you had removed though, as Mike is using a cork gasket between the spacer and pan, not Hondabond as your car appears to have.
Mike, the kit Carl sells comes with two cork gaskets that create a sandwich around the spacer. I'm wondering, though, whether instead of a cork gasket, perhaps a gasketmaker (thinner but accomplishes the same result) would leave more room for all of this to fit together. A bit late now for that...
It's a shame to have to reinvent this process.
I was in touch with Greg originally but none of the other bits I needed to complete the kit were available from anywhere (pre 82 oil pick up, screen, cloverleaf); Based on the thread I linked to before, I'm guessing these spacers are all basically the same (other than the instructions!)
After talking to Greg Brown, it's on my todo list also. Interesting problem with the starter. Good to know before getting into it.
Anyone have an early oil pan and pick up laying around? Van volunteered his, but we'd have to remove it from his car first. Would be easier (and less likely to mess up a fine car) if someone had one available.
George
90 S4 Grand Prix White (Murf #5)
94 GTS 5-Speed Midnight Blue
06 Cayenne S Havanna/Sand Beige (PASM)
http://928.jorj7.com
George
George
Is there any actual evidence of the old-style pan and pickup working better than the new-style pan and pickup? I don't have any contrary evidence, and certainly it looks like the old-style setup is more expensive to make so it's plausible that they went to the new style for cost control reasons. Just that I'd like to see some data on this if someone's got data.
George
