Compressor Seal ?
Compressor Seal ?
No number available on compressor: 87 924s
I am rebuilding my compressor and have a kit; Nippondenso 10P shaft seal kit SK-753N listed on package; I ordered a few months ago, the invoice called it a SK-753G kit
The kit has an extra O'ring for the original seat but also included a new seat in the kit. The seat if different lacking the extractor lip on seat.
The seal is shorter but seems to have the same ID, do I have the wrong kit or is this compatible?
An '87 924 has an ear-mount Nippondenso 10P15E compressor. It has a 2-piece spring carbon shaft seal. I don't know what SK-753N is, but SK-753G is the correct seal kit for it, but you will also need the rest of the o-rings which come in kit KT-10PN. Some shaft seal kits contain an extra o-ring and yes, the seat can sometimes be shorter but that should be ok.
Dan
'91 928GT S/C 475hp/460lb.ft
Dan
I installed it and it is leaking, I have it on the bench pressurized with nitrogen. I reused the old seat with new O'ring and installed the seal with a socket by hand. The circle clip seemed to hold it in place even though the height is shorter. Seems like this has been a problem for me to get anyone of these seals to work on my other compressors.
Under the Lift
Dan
Dan
Just wanted to see if anyone was paying attention!
This group has the most knowledgeable members on the forum so I sneaked it in
This compressor is the type you can change the seal from the front with out cracking the case, I may have the wrong seal, the numbers I can read are 10P15E on the compressor.
Chronic Tool Dropper
<< duplicate post >>
Hmm, I was under the impression that the 924's had the early 10P15 with the 2-piece carbon seal. If it is the later 10P15, you will need a lip seal like this. You will also need the tool that slips the seal onto the shaft. You can try without the tool, but there is a good chance it will leak.
Dan
Dan
I have had enough found a shop in Lauderdale Polar Air they will reseal, test to 300 Psi and return for $100 not worth the aggravation. I could not locate a seal installer or guide for this model so this is my best option turn around in 2 days.
Received my compressor back vac it down and went to charge it. I only took about 3 oz then stopped. Checked gauges low of 90 high of 20 does this indicate a open expansion valve. I am assuming this is buried under the dash or should I be looking for something else?
