crank bolt not coming loose.
#32
Chronic Tool Dropper
with my max 200 NM torque wrench i could not even fasten it to max on the engine stand as danger of flipping it over.... so must be done in the car now . Tomorrow i have a borrowed bigger one to get it up to 300 NM.
I assume this is for a dry bolt/thread and not greased.
I have a pretty hefty 3/4-drive impact gun. It requires a full 1/2" hose and fittings to make any more torque than my 1/2"-drive impact, so I've added some connections and a 25' hose directly to a compressor tank fitting just for this duty. It's only been used a couple times, when I needed the "impact" function more than the torque capability when I couldn't counter-hold something adequately by myself.
#33
haha, i got a borrowed + 1 m 1" torque wrench today …. just nothing special to get 300 NM. Easy . Think it was 1/2 ...3/4 turn more than 200 NM , but don't be certain, as i didn't got it probably to 200 NM in the engine stand.
#35
If you have immediate local access to a 1 1/16" impact socket, it will do the job just fine. It's about half-a-thousandth (0.000492") of an inch larger than 27mm, well within the manufacturing tolerance of any broached impact socket. The oxide coating on the socket probably makes that up.
#38
Yes, that looks rather corroded. Gotta wonder how that happened. Maybe somebody put something on that bolt. It's supposed to go in clean and dry. I would scrub the threads inside the crank nose with a toothbrush and some solvent, rinse it, and let it dry. It looks like the finish is gone on that bolt. Consider getting a new one.
#39
#40
""""Put a long enough breaker bar on it that it will reach the floor. Stuff a sheet of plywood to protect the radiator. Then just tap the starter""""
An old experienced tech showed me this why of crank bolt removal 40+ years ago,when a lot of shops had no air compressor.
I haven't used it in decades,but that made me smile when I read it.
Today,when it won't come out,I grab the 3/4 inch,impact gun that is.
However I tried it on my other car and no such luck
I ended up holding an electric impact wrench on it for some minutes, and then it came loose
Not so easy to do in a 928 unless you remove the rad, and possibly the aircon condenser as well
#41
i would a least check with a thread chaser ( or tap .. or the new bolt ) on the crankshaft.... otherwise you won't have any idea if torque is right with a new bolt. You could end up with the 300 NM and the balancer still "loose" .
