928 Forum 1978-1995
Sponsored by: 928 Specialists
1987 928 Block w/scatch
Old 05-15-2013, 03:44 PM
bilwilli
bilwilli's Avatar
Default 1987 928 Block w/scatch
I have a 1987 928 S4 block which a small scratch in one cylinder.. if the block is Alusil ( which I am not sure of ) would it be less expensive to fix it with that process or go with Nickasil which has to strip all the Alusil off...This car is for normal driving...so I would like to do the job for as reasonable as possible..
Thanks for any input,
Bill
Old 05-15-2013, 03:58 PM
Kevin in Atlanta
Kevin in Atlanta's Avatar
did you get a lower compression on that cylinder?
Old 05-15-2013, 04:34 PM
bilwilli
bilwilli's Avatar
This was discovered after engine was taken apart..piston was dirtiest of the group
Old 05-15-2013, 04:50 PM
G8RB8
G8RB8's Avatar
Might not be worth worrying about. Post a pic.
Old 05-15-2013, 04:55 PM
bilwilli
bilwilli's Avatar
I will post a pic this Friday...
Old 05-15-2013, 05:19 PM
Fabio421
Man of many SIGs
Fabio421's Avatar
Bill
You cannot "scrape off" the Alusil. The block is made from it, not coated with it. You can send the block out to be Nicasil'd if you think it's no good in it's current state.
jeff spahn
jeff spahn's Avatar
Bilwilli. I had a lot of large scratches in one of my cylinders. I just left them in and put in new rings when I put in a new piston. Something got in, beat the crap out of my piston, but not the valves. Talked to a few well known 928 repair guys here on Rennlist and they basically said "Are you going to race it". "NO?" "Then put new rings in it and put it back together." Best advice I have been given in a long time. Car runs great. Has good compression and leaks/burns no oil.
You could easily feel the scratches in mine with your fingernails.
Old 05-17-2013, 05:23 PM
bilwilli
bilwilli's Avatar
Default 87 S4 Cylinder w/scratch
Hope this pic helps....this one is the worst of the group....Can these cylinders be honed?
Thanks, Bill
Old 05-17-2013, 05:55 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,443 Likes on 1,372 Posts
clean the head gasket surface,
install new rings and run it,
the scratch is negligible
Old 05-17-2013, 06:42 PM
BC
BC's Avatar
It is quite easy to relapp the cylinders for new rings, essentially preparing the surface for bedding in the rings.
It involves a paste, and some felt pads on a expanding hone or some form of one.
http://www.goodson.com/AN-30-Silicon...und_for_Honing
http://www.goodson.com/MM33-FO5_-_Fe..._Alloy_Blocks/
Last time I did this it was over 500 dollars for the block, but I think that involved hot tanking. This time I bought this stuff and will do it myself.
Old 05-18-2013, 12:37 AM
G8RB8
G8RB8's Avatar
+1
Not that Stan needs it.
Old 05-18-2013, 01:50 AM
GlenL
GlenL's Avatar
Ignore the scratch. Use some solvent to clean the bores. Don't scrape. Don't hone them!
Old 05-18-2013, 04:49 AM
Tails
Tails's Avatar
+1 to Stan's post #9. The dirty piston is probably from the small amount of oil passing the ring and burning in the combustion chamber.
Old 05-18-2013, 02:38 PM
mark kibort
mark kibort's Avatar
if you had the block in a position to get it re-pasted, i would do it. but , it probably will be fine.
Old 05-18-2013, 03:16 PM
depami
depami's Avatar
Thanks, Bill
Do not hone. Those scratches are minimal, just ignore them.
And by all means, get that chevy symbol away from your engine.
Chevy mentality has no place near a 928....
Quick Reply: 1987 928 Block w/scatch
