Gates Timing Belt Comparions - Regular vs Racing
Under the Lift
I'd like to know the "stretch" in timing degrees after the belt has "settled" in. I've never noticed any "stretch" with the standard Gates, but I may not have been looking close enough.
Doubling the valve spring pressure may require a stronger belt.
Under the Lift
Oh, I see Ken has looked at this and found 2 degrees "stretch" with a regular Gates belt and none with Gates Racing on a motor with stock valve springs, I assume.
https://rennlist.com/forums/10428821-post54.html
ive seen no stretch, but maybe like bill, i havent looked hard enough.
certainly no failures (yet) and ive used the conti for over 15 years now just because it was what the supplier always sent me at engine build or rebuild time.
Inventor
Inventor
With standard belts, I think there may be some high rpm retard as the belt reaches its compliance limit. (Variable valve timing! )
My only concern with the racing belt is setting the belt tension, seems the belt would change the forced required to twist it thus making my tensioning tool useless
Basic Sponsor
My only concern with the racing belt is setting the belt tension, seems the belt would change the forced required to twist it thus making my tensioning tool useless.
Twist or bend, what is measured is the force to displace the belt some amount which makes me think two things:
Belt that doesn't stretch as easily will measure higher at the same tension as stretchy belt.
A compliant tensioning system, like Porkens, will have roughly constant tension, so it will measure lower at the same tension as on a non compliant tensioner system.
Basic Sponsor
Belt construction is the same - only the grade of the material has changed.
There are at least six manufactures of this belt that I can think of and they all use slightly different materials and maybe different construction criteria. But we all use the same tools and settings to tension them.
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Fixer,
I don't 'believe' the racing belt has MORE reinforcement, it just has better reinforcement. The OE belt is reinforced with fiberglass, while the Racing belt is reinforced with Kevlar. Kevlar is a synthetic polymer, developed by and produced by DuPont (our neighbor to the south, and my former employer). Kevlar cord is like any fabric cord - nylon, polyester, polypropylene, etc. in that it is highly flexible, and in the Kevlar case, it is very difficult to cut compared to other polymer or natural fibers. Tying it in a knot has very little effect on it's strength - try that with fiberglass! It will survive many times more flex cycles than fiberglass, and it has essentially no stretch until it is near the tensile breaking point.
IF you were into automobiles in the '60's and '70's, you may remember when fiberglass was used as a belt in bias (and even a few radial tires). It deteriorated quickly, as the fiberglass in the belts broke. I was involved in the evaluation of Kevlar in radial tire belts, from passenger tires all the way up to the giant mining tires. Never any problems with the Kevlar breaking - it was just too expensive to commercialize. It also has high temperature capability vs both fiberglass and the other polymer fibers, and is unaffected by moisture.
Thus, in automobile applications where temperatures to 250+ degrees, and moisture (hoses), or high flexing no stretching conditions (belts), it is an ideal reinforcement for rubber. Again, the products containing it are more expensive, as the fiber is significantly more expensive. The mfg process is VERY complex and technically challenging.
Actually, when you get right down to it, when you consider JUST the reinforcing material, the Kevlar is MORE flexible than the fiberglass!
Gary Knox
Gary Knox
