converting from auto to manual?
#31
Yes it's safe to be manually shifting the auto box.
I've converted two cars. A suggestion is to just use a floor mount clutch pedal with factory slave. The stock system is a bitch to bleed and get right. Top that off, if your clutch master bracket isn't added just right it will chew through masters at an alarming rate.
Other than that it all just bolts right in. Also, get the dual disc, it's a much nicer setup!
so these paddle shifters are for auto trans?..... hmmmm. I wonder if that would give me enough functionality to make it a fun track car for twistys and such.
#32
yes sir. hey I am just going on what someone else posted. their 6spd vette transaxle swap appears to have gone off legit without issues.
#35
This one is being installed now & is matted to a LS376/525 motor. Both T-56 6spd manuals. https://rennlist.com/forums/928-foru...b-project.html
On the drawing board is the GM 6l80 6spd auto trans with paddle shift, or maybe an auto tap stick like MB used on some of there later models. T
#36
This one is up & running matted to an 82 S.C. 4.5 motor with no issues: https://rennlist.com/forums/928-foru...swap-pics.html
#37
seriously though, will a sbc mate with that vette 6 sp trans without issues? Could I possibly even use a vette torque tube for this, and cut the "928" completely out of the drive train?
