Header fitment question
I just received my new headers today and I thought I would test fit them.
The first set had the wrong flanges welded on. On these the hole spacing seems to be slightly off. How hard should it be to put these on? I think I would have to use a rubber mallet to seat them. Also how flat should the sealing surface on the flanges be? There is weld-thruogh on three of the flanges on one of the headers.
Former Sponsor
They are going to need to be really flat to seal against the stock gaskets.
Where is that thread about why headers for these cars cost so much?
Is that dent in the first picture from the factory?
when turning to the right under throttle I get a little noise through the steering column when the shaft apparently touches the header. didn't see that when putting the rack back into place.
need to get in there and see what I can do to increase clearance without R&R them.
good luck.
Administrator - "Tyson"
Probably could have saved some money if I have known to buy direct from msds.
Just one more mistake I've made. But I believe in supporting our vendors. The headers were just one part of a large order. Tried to save money on shipping.
