Where is the horn on my 1982?
I have been crawling all around this car for a few weeks and just realized I have not run across the horn. Where should it be? It doesn't work, so I cannot listen for the location. Thanks!
Chronic Tool Dropper
Just replaced mine with the commonly-recommended Wolo "Bad Boy" horn. Had to fab a small bracket (a few inches of 1" x 1/8" aluminum angle) to hang it upright, but otherwise a plug-in. It's louder than original but still the two tones. HF stores stock them. If you need to replace yours, this is a reasonable option.
A recent incident with a sleep-driver prompted the change for me. There are times when a freight-train horn is needed, but most times we just need a gentle toot to wake someone texting as the light turns green then red again.
Archive Gatekeeper
Six replies and no pictures? Sheesh....
Here's a kiloword for y'all.
![](https://webfiles.uci.edu/redwards/public/Hebert%20RF%20wheelwell%20lightint%20wiring.jpg)
On an early car, they may look more like these once you remove the splash panel in front of the wheel (ignore the aftermarket charcoal canister added as a federalization attempt).
Here's a photo of the horns in my old 81:
![](http://928.jorj7.com/images/horns1-z.jpg)
From my page at http://928.jorj7.com/horn.html (circa 1999)
George
90 S4 Murf #5
94 GTS
George
90 S4 Murf #5
94 GTS
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
I know: Old thread. But I'm reassembling the right front fender on my '82 and I couldn't remember how the horn bracket attached and I found this thread.
And that's funny right there, I don't care who you are.
better Shawn, i checked al electrics on my rally build to see only the horn didn't work.....checked wires, relays etc... to finally see there was no horn at all.. no wonder i didn't work
Shawn Stanford (04-14-2021)
