ZDDP in oil
#32
Sure wish I had some of you guys around when I was taking Organic Chemistry 101 about 52 years ago (believe it or not I did get an "A" in the course). Seriously (when am I not serious when it comes to maintaining my 928S4) I have the impression that, since my engine virtually never goes north of 4000 rpm (and I preserve my wallet by not burning rubber or driving much above the speed limit in Wyoming) I should be OK just using Mobil 1 15w-50. If there is a special additive available at one of the usual car shops or WalMart that someeone can recommend, I'll buy it.
#33
Here is the chart.
http://www.mobiloil.com/USA-English/...duct_Guide.pdf
BTW, no one has told you not to trust them.
#35
"Porsche do not recommend a diesel oil in a petrol powered engine , not last century & not in this century. Now why is that so ?
Answer = primary diesel oils are very high in detergents( compared to petrol powered oils) and these detergent packages tend to make engine oil foam too easily , so they then add silicon to reduce this tendency , but detergents attack the ZDDP , thats why primary diesel oils look as if they have very high ZDDP( new) , but as time goes by the ZDDP is damaged by the detergent packages .
Now back to the foaming , if a petrol engine from last century revs harder to make its max power as opposed to a diesel engine from last century ( like for like) this in quite normal , so in a big rig that cruises on the freeway at 1,800 RPM will give the oil way less tendency to foam as say a sports car / GT engine that is being revved to 6,500 RPM a lot .
This is where it gets interesting , foaming / air bubbles in the oil is the VERY last thing you need in a 944 / 951 or a 928 , because they have a very small flaw in their crank oil feed design , they starve no 2 con rod bearing ( 944 / 951 / 968 ) and 2& 6 con rod bearings on a 928 if the oil pressure drops to low."
"...the only thing that works is a 20w-50 ( never fails ( so long as the engine is not already badly damage by running around with a low vis oil."
I hate to be so dumb but, doesn't the above represent a contradiction? Sure, the last bit is presented in the context of high-core temp conditions; however, on the one hand I think I am being told not to use 20w50 and on the other, I have the expert's blessing???
When I look up diesel oil I find that manufacturers such as Amsoil and Valvoline say that their 20w50 is fine for both diesel and petrol engine applications. I admit that I don't find such a recommendation in my Owner's Manual; however, that is the crux of the matter isn't it? Today's diesel oil = last century's petrol oil n'est pas?
As for the foaming, I've yet to see that while running Rotella diesel oil.
#36
Someone must have answered this question here
Not trying to ruffle feathers, Sean. Just looking for further education as it appears others are as well.
http://en.wikipedia.org/wiki/Zinc_dithiophosphate
#38
Basic Sponsor
Austin,
It is pretty simple in my book - Mobile 1 does not state what level of ZZDP it puts in its oils at any one time. They changed the level when it was known to effect the performance of a cat. They changed it back again. That is called "Flip Flopping" and I for one need something more reliable than that. There are oils out there that cost a little more but maintain the correct level of ZZDP. I chose Royal Purple because they are consistant about exactly what level of ZZDP is in the bottle.
As I only change my oil every 12 months of 15,000 miles the additional cost v the peace of mind is tiny.
I have about 16 928's and they all use Royal Purple. Apart from the one in the UK which will be changed once it reaches these shores.
I listen to real stories from people like Bruce Buchanan who has worked on more 928's than I have had hot dinners.
You pays your money you takes your choice.
Best,
Roger
Best,
Roger
#39
oil and additives
I have yet to see a jug of oil that lists the ZDDP content on it. I buy at the retail auto parts stores. I have never once seen this listing on a label, no matter which store I go to. How do you know what the content is when you buy your oil (unless you special order a royal purple or amsoil or whatever). I am only talking about retail.
#41
Mobil 1 chart http://www.mobiloil.com/USA-English/...duct_Guide.pdf
I'll stick with the M-1 15-50. T
#42
whew - I was hoping this wouldn't turn into this
I was just bemoaning the lack of info on the label, making it hard to determine what brand to buy when at the auto parts store. I have read just about every oil thread over the years on this board too. there is lots of good information on this here. I use Castrol GTX 20-50 or similar, but when that isn't available, I like to know what the alternatives are, while looking at the jugs on the shelf, and not have to waste time and run home and do a research project.
I think I'm convinced that finding and sticking with a local Royal Purple rep will be the way to go. There is one that lives not too far from me.
#44
Ed, rest assured that I am not participating to pick a fight. Just looking for facts. I wouldn't make this conversation about anything else. I appreciate and respect Roger for his part to keep the 928 alive and thriving.
If you are at all under the impression that my questions are muddying up your thread, I am happy to continue this conversation with Roger privately.
#45
Carry on all
