I might just cry (belt tensioner warning)
#61
Truthful I'm on a budget, so i really need to be careful on how much i spend. My wife wants the car gone now that it broke down. Thanks on regards to the future parts questions. I will have many!
#67
There may be nothing wrong except a loose belt.
Yes, some of them need do indeed need retensioning with stretch.
Better pictures required.
Economy job is possible but you've got to give more / better info.
#69
Shameful Thread Killer
Team Owner
before you do more troubleshooting please spray down the area with some brake cleaner,
do you see a crack in some part where your shining the laser?
The orange O ring is a seal for the dipstick tube.
If the car bottomed out then its possible that AC mounting parts could be damaged / cracked the engine hitting things is due to two things,
worn motor mounts and a improper ride height setting, this bottoming out can also effect the alternator mount on the girdle of the block
#72
Great advice, i started cleaning up the surrounding areas to see if any surface cracks arise. Besides getting high in the garage afterwards, i did not see any cracks or problems as of yet. I'll keep my eyes open for now. Had the open the garage...cough .....!
In regards to the pulley which is engaged by the tensionor. The removal of this part calls for a 4mm bit or Allen wrench. I first noticed the bolt was already stripped. Dwayne instructions warned about how soft the allen head was...butter i would assume. I sprayed the back side with pb blaster and let it sit for awhile. I clean up the area and tried to remove it. It would not budge at all and of course the allen head is stripped. I tripped tapping in the allen head and going up a size. No dice.
How do i remove it now? I would assume i need to get a grinder and remove the bolt head?
The tensionor, if i decide to rebuild, how many miles are too many miles on the tensionor i have? It has atleast 240k or more on it.
#73
Do you have an 3/8 or 1/4 ratchet with a torx bit? Tap it in to remove the screw. If all fails simply drill the head off. Plug the dipstick hole in the pan first.
240k for a tensioner is not too much, age is. The boot should be soft and pliable, yours is probably hard as a rock and broken if it still is original.
#75
Captain Obvious
Super User
Super User
