WWII German smoke screen. (update)
Is the smoke only on decel? Could it be sucking in through the heads?
If you replaced the rings but didn't relap the bores it may take a bit longer for them to seat.
5300 ish.
no crank case gases can get to the intake... NONE
crank gases go to a provent filter canister then straight to the exhaust.
here is a picture that shows the filter set up. minus the hose to the exhaust evac valve.
i did not touch the bores.. other then a clean rag.
how long can it take? my thought would be why did it do all the smoke that one time, but not before..
mysteries!
mysteries!
wait a sec.....
do you only have that one tiny line feeding the provent?
You really need to have more than that or your crankcase pressure goes up too high, lifts rings, and BAG smoke screen!
Hmm.....here is my thoughts............new rings sounds like a great idea, BUT if the existing rings are in good condition LEAVE THEM....they are already seated properly to the existing bores.... The really only correct way to change the rings is to lightly hone the bores at the same time....so a clean bore mates with the new rings.....think about it....lots of little tiny matched lands and grooves in the rings-bores....now you put new rings....so its lots and lots of little gaps?
If you had a stock-ish breather I would say classic pressure issues...but thats not possible with your setup..... Have you tried attaching a mityvac to the crankcase....then rev it up.....it might surprise you & in a good way, since this is your best case scenario....
But at 5300rpm for a brief "burst" you shouldn't have any issues at all......that is scary..... I run my racers to redline 4-5 times every 2 minute lap.....for hours per day.....I typically burn 1/2qt per day & get only a few drops in my "breather-vent"....
Brian, please re-read. He has already put in new rings.
Duc,
-12 is only 3/4" this is way way to small!
I would run a minimum of 1" off the filler neck and consider one 1/2" off each cam box.
If he is running the ign map I sent him still it's good and shouldn't be creating any issues. But that said, what is your CR at now? Pulling 3 deg out of the upper end might help if CR is really high.
Duc,
Duc,
Duc,
Craic Head
Jake,
You were running on the dyno the other day too, right? No smoke issues with that? You had to go to redline that day, or pretty close.
So the car's got a few hours on it, including some dyno runs and then you took it out and on one or more trips up to 5300 it started pouring out black (oil) smoke...
The car runs fine at low RPMs and you can't see any obvious signs of oil? How much oil is showing on the dipstick? Can you tell how much you're down?
Have you done a compression check yet? I'd do that on all cylinders to see what you've got there before proceeding...
Today im going to pick up a compression tester kit and give that a whirl.
i ran a similar vent set up on the stock engine (no vent to intake, stright to the exhaust off the oil fill cap) and NEVER had any smoke or oil issues. the provent was not filled with oil, line to the exhaust was good and clean. and the oil level was good.
Mike, after one dyno pull there was the slightest puff of smoke when he let off, to small to tell the color. and that was it.
think i figured it out. #5 was the worst when i checked last night. had oil even around the plug inside the plug hole.
well today i checked again.. yep UV dye and my tasted buds confirmed it. Coolant.
SO, should i even run compression checks? (i bought a gauge at the local parts store)
looks like out she comes. i will drain the oil and see whats in there.
anything else i should check? if it is not in the oil im guessing my rings are ok?
Calm down and relax is step 1
Probably just a stuck ring.
Please give us all the info on the bottom end.
As in where is it from? Did you remove pistons?
Also is there oil in the intake?
It's possible that you had a bunch of oil in the intake that got sucked up and that's what you're seeing.
Well it took the plugs out. 1-4 plugs looked ok, but oil was all over the pistons and pooling in the valve reliefs.
5 and 6 were the worst. coated in oil. 7-8 looked ok.
time for her to come out and go in the trash (block). hope the pistons are ok.
or i should just do the LS mod.
FML
FML
Pistons are probly fine...
THIS..is what I'll also see after a WOT 1st, 2nd, and into 3rd gear run even before the supercharger. Id do that burst at lunch in the last 1/2 mile to the office, come out at 5pm, and blow a cloud as the oil picked up from the bottom of the intake was spit into the upper intake..then ran down to the intake valves as it sat.
Yup.
Yup.
im the same way. i raced all weekend long, brutalized my engine and still only used a half a quart alll weekend, with a 30min race with all redline shifts. no smoke, no oil burn , alll stock breather stuff.
its got to be something else. rings are wrong (and i think they can be installed upside down too) or valve guides then.
plus, if you have all that water on a hot piston , let it sit for a few mins and it will evaporate quickly. oil will not.
do you remember the video of scot blowing a water hose? or his slightly blue smoke acceleration at thunderhill pasted the left hander, at the turn 8 kink?
